Wheelin' and a P0441?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by socal4x, May 25, 2012.
  1. May 25, 2012 at 8:27 PM
    socal4x
    socal4x [OP] Well-Known Member
    CA
    '16 MGM DCSB OR 4x4 6MT
    I was out wheeling this week and big granite boulder came up out of nowhere and hit the back of my truck...bent the exhaust pipe into the rear wheel. After I bent it back, I got a check engine light. When I ran the code, it gave me a p0441, and p0441 pending.
    I know this is evap emission control sys purge flow fault, but does anyone know if this is from the impact?
  2. May 25, 2012 at 8:35 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Quite possibly. Your charcoal canister is back there. Something could of jarred loose or broke.
  3. May 25, 2012 at 9:04 PM
    socal4x
    CA
    Thanks...I'll check it out tomorrow.
  4. May 26, 2012 at 2:31 PM
    socal4x
    CA
    Okay, so the "s" bend in the exhaust pipe hit the corner of the canister and cracked it. Stupid low hanging TRD chrome tip:facepalm: I will be cutting that off.
    Anybody know if these canisters can be epoxied or is it trash now?
  5. May 26, 2012 at 2:37 PM
    stangkeip10
    stangkeip10 Well-Known Member
    Cincinnati
    '10 Magnet Gray 4x4 Access Cab SR5
    BHLM, Black OR TRD wheels, BFG Mud terrains, yellow wire mod, 5100s @ 2.5, toytec tsb aal
    i cut my exhaust after the rear axle to avoid that from happening.
  6. May 26, 2012 at 6:04 PM
    toy.tech21
    toy.tech21 Active Member
    Evan
    Lakewood CO
    2008 Doublecab 6 speed
    K&N intake, URD short throw shifter, toytec boss front coilovers, old man emu dakars, led's in gauge cluster, dome and map light led's
    Sorry man if its cracked then you cant do much. It needs to be replaced.
  7. May 27, 2012 at 8:48 AM
    socal4x
    CA
    It cracked at the bracket. I partially removed it, didn't disconnect any hoses. What a piece of shit. The plastic is super flimsy. I used plastic weld epoxy to put it back together.
    They are about $288 new, online. Has anybody done this work on their own? I have heard that the bed has to be removed, hoping that is not the case. Wondering what it takes -- purging the fuel line, etc.? -- I have no idea how to do that.
    I have seen some posts for $400 at the dealer. Is this price accurate?
    It looks like the new box can just be plugged in, code reset, etc. -- but I am assuming its not that easy?
  8. May 27, 2012 at 10:24 AM
    krans
    krans Well-Known Member
    Kenny
    Huntington beach/ West min duh
    09 Sport mall crawler
    Icon extended travel with resi front and rear,Camburg UCA, All pro standard leaf pack, Fogs anytime, General grabbers AT2,Custom stainless steel brake lines,bed box, Bestop soft top,50' light bar, amber rigid pods,CBI ditch mounts with LED pods,TRD intake,Anti dark hoodlights/rock light/LED whip,FX-R retros and Gibson catback..more mods to come
    It's just a EVAP system no actually fuel inside,just unhook everything and replace as needed clear the code and your set. Pm me for OEM parts or help.
  9. May 27, 2012 at 12:10 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Your epoxy job work?
  10. May 27, 2012 at 2:46 PM
    socal4x
    CA
    Thanks, I'll keep you in mind.
  11. May 27, 2012 at 2:55 PM
    socal4x
    CA
    Possibly. It may be too soon to tell.
    I disconnected the neg batt. lead. I used some devcon plastic welder and slathered it on. After an hour, I reconnected the batt., started the engine with the scanner attached, no codes.
    So maybe it worked? I didn't have to clear the codes.
    I am letting the epoxy cure for a few hours before I remount the can to the bracket, its just hanging now.
  12. May 27, 2012 at 2:59 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
  13. Jun 3, 2012 at 8:47 AM
    socal4x
    CA
    So its been about a week, I've been driving around normal, no codes yet. I'll probably get one after this post.:D
    The bracket mount is the problem, I think this box should probably be clamped on with a band type clamp. Anyways, after the epoxy job cured, I sprayed the whole thing with Krylon leak seal rubberized coating to cover any pinholes or small cracks I might have missed. Also the theory is that if the cracks re-open, the rubber provides a bit of a flexible barrier...again time will tell.
  14. Jun 21, 2012 at 8:51 AM
    pLon
    pLon Well-Known Member
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    Still no codes? :O
  15. Jun 23, 2012 at 4:58 PM
    socal4x
    CA
    No, they came back...0441, and now 0455:mad: Oh well.
  16. Feb 6, 2013 at 2:29 PM
    Twirlin
    Twirlin Nature just gets the blow-by
    WI
    '10 TRD Sport Mag Grey
    i have an 0441 on my '10 TRD sport.
    about to take it to a dealer to have it looked at.
  17. Feb 7, 2013 at 3:10 PM
    socal4x
    CA
    I forgot to update this. Toyota replaced the whole charcoal assembly and associated emissions under warranty...
    Guess I got lucky -- a little charm towards the female service writer always helps:D
  18. Feb 13, 2013 at 3:47 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    Would you mind telling the parts (with PN if you can) that toyota changed?
    Also do you feel a difference? more MPG or something?
