Wheelin in a 4cyl. 5 spd.
Discussion in '4 Cylinder' started by SoCalTbird, Feb 2, 2021.
  1. Feb 2, 2021 at 3:22 PM
    SoCalTbird
    SoCalTbird [OP] Well-Known Member
    South OC
    06 PreRunner DCSB 05 AC 4X4
    This may be common knowledge round these parts, but new to me. Finally took my truck wheeling after about 6 months of ownership. Pleasantly surprised how well it will chug along in 4H in 1st gear with no input from gas or clutch. Prior to this i was a little disappointed with the slow revving(heavy flywheel), now it makes complete sense. That is all
    Bizquick, 05Taco4x4 and H860 like this.
  2. Feb 2, 2021 at 3:33 PM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    Welcome to TW fellow 4cyl 5spd 4x4 owner.
    I have to say my experience is actually the opposite of yours. While it will chug along just fine in 1st gear high, I often need to slow down for a rock, or a rut, and then I'm going too slow for 1st gear so I have to use the clutch. I've found it's much easier to chug along in 2nd gear low at slightly higher rpms, which gives me plenty of flexibility to speed up or slow down without using the clutch. 3rd gear low seems almost identical to 1st gear high, so that ratio is still available if needed.
    Cheers :cheers:
    H860, whatstcp and SoCalTbird[OP] like this.
  3. Feb 2, 2021 at 3:37 PM
    SoCalTbird
    South OC
    i will definitely try this next time, it just seemed silly(at the time) to use low, when it didn't seem necessary. You make a good point, and i know felt what you are talking about. Since it was first go around with this set up, was tryin to feel it out. :cheers:
  4. Feb 2, 2021 at 3:39 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
  5. Feb 2, 2021 at 3:41 PM
    rocky_mountain_dave
    David
    I often use 4L long before I need 4 wheel drive, just for the lower gearing. If it were a V6 or an automatic it would be different. But I love the powertrain, wouldn't trade it and it does everything I need it to.
    SoCalTbird[OP] likes this.
  6. Feb 2, 2021 at 3:45 PM
    Mixalot
    Mixalot Well-Known Member
    Kansas City
    2019 Tacoma TRD Off Road
    Jeez nice view.
  7. Mar 4, 2021 at 5:56 PM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    Another vote for 4-Low and go. I shift to 4L immediately when getting off road 80% of the time, it's a much more enjoyable way to drive the 4cyl/5 speed combo. The only time I leave it in 4-HI is street driving in the snow or a flat dirt road (if needed)
  8. Mar 5, 2021 at 3:52 AM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    Im all for 4lo too when wheeling. I have a throttle controller on mine, i plan to test it in ECO mode 4lo this summer. Should crawl nice and slow. I am interested in the 2wd Low mod too, im waiting until it is available again on here from a member.
    whatstcp likes this.
