Wheeling with Spacers?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by imjustabill1970, Oct 20, 2017.
  1. Oct 20, 2017 at 10:24 AM
    imjustabill1970
    imjustabill1970 [OP] Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    Anyone wheel here on a regular basis and have wheel spacers? If so, what brand and thickness are you using?
    Later.
    ChadsPride likes this.
  2. Oct 20, 2017 at 10:25 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Wheel spacers or coil spacers?​
    siznarf and HSmith_11 like this.
  3. Oct 20, 2017 at 10:26 AM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    I assume you mean wheel spacers.
    Buy some 1.25" to 1.5" Spidertrax and you'll be fine
  4. Oct 20, 2017 at 10:29 AM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    I wheeled with 1.25" Spidertrax spacers and had no issues. Just make sure you use the Loctite and torque the nuts down to the required torque spec.
  5. Oct 20, 2017 at 10:34 AM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    I have a complete set of used Spidertrax 1.25 for sale.
  6. Oct 20, 2017 at 10:53 AM
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    Just make sure to get a good quality hub centric spacer, like Spidertrax (there are others as well, but I've always used Spidertrax). Use red loctite, and torque them to proper specs (use a torque wrench, never use an impact!); and they'll be no different than running the equivalent backspaced aftermarket wheel. Double check the spacer lugs after the first 50-100 miles or so, then just make sure to double check them during tire rotations. When I check them, I just set my torque wrench 5lbs lower than the torque spec as to not risk breaking the loctite bond; I've never actually had one move, but if it did, I would re-loctite and re-torque to spec.
    I've done plenty of hard wheeling running spacers on jeeps, and also currently have 1.25" on my Taco. Have never experienced a failure.
    Big tall dave likes this.
  7. Oct 20, 2017 at 11:13 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I have both installed on my 17. Wheel spacers are gtg, I’ve never had any issues. Buy quality/hub centric and re torque after recommended number of miles. Anyone who says they will wear out your bearings quicker is right... but they have no values to offer as to how much quicker, and most people including myself believe the “quicker” wear is so negligible it’s a non issue.
    Lift spacers are dumb as hell unless you do your homework and make an educated decision. If you’re not ready to LT your truck, or at the very least put some fox coilovers on, then MY opinion is toytec half inch spacers up front, leave the rear alone. That gets you one inch lift up front without risking damage or unintended wear on your other components, doesn’t fuck up your ride quality, doesnt bugger up your factory geometry, and again, my opinion, puts you in the Goldilocks zone until you choose to go balls out.
    Stick out like this depending on your wheel specs
    hiPSI, Jukeboxx13 and Dirty Harry like this.
  8. Oct 20, 2017 at 11:20 AM
    erok81
    erok81 Well-Known Member
    Imposter
    Do you guys really throw on locktite right off the bat? Seems to me you wouldn't really be able to retorque after x miles.
    With that said I've run spacers on high horse power cars and on my Tacoma. The Tacoma has seen a lot of rough off road miles. I've never used locktite and just retorque once.
    Due my problem of not being able to leave things alone I probably have the wheels/tires off once a month. I always check wheel spacer torque when they are off and have never found a loose lug nut.
    Agreed from above. Use a quality spacer like spidertrax or bora. Good wheel spacers aren't really that expensive so don't cheap out on them.
    rlx02 likes this.
  9. Oct 20, 2017 at 11:31 AM
    kbp810
    Au Gres, MI
    2016 Tacoma TRD OR
    Not so much re-torquing, more so just confirming that they're still tight. That's why I set my torque wrench 5lbs lower than spec when I re-check torque; that way I don't break the loctite bond, but if any have loosened that's still going to let me know.
    Though like you, I've also never found a loose lug.
    Big tall dave and erok81[QUOTED] like this.
  10. Oct 20, 2017 at 11:36 AM
    Devil Dog
    Devil Dog Tacos, Tacos, Tacos, come and get your Tacos
    Philly Burbs
    2017 Tacoma TRD OFF ROAD 4x4 Double Cab / Inferno
    5% Tint, cargo tray and organizer, 1.25” Spidertrax spacers, TuffSkinz raised tailgate letters, Air compressor, Bed Extender.
    PM inbound.
  11. Oct 20, 2017 at 11:37 AM
    gargamel05
    gargamel05 Well-Known Member
    Bay Area,CA ---> Easton,PA
    I ran Spidertrax 1.25 spacers on my 2014 4Runner Trail edition. Studs snapped and broke off. Ever since then, I never run spacers on any of my trucks ;-(
  12. Oct 20, 2017 at 11:49 AM
    Devil Dog
    Philly Burbs
    Really? Wow!!
    I'm assuming they were installed correctly and am wondering what the scenario was when this happened? Extreme wheeling? All wheeels had the studs break or??
    Most folks on here seem to have had no issues...
  13. Oct 20, 2017 at 11:56 AM
    imjustabill1970
    bill
    clarksville, tn
    Thanks for all of the responses...yes, I meant wheel spacers.
    Later.
  14. Oct 20, 2017 at 12:08 PM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Dude, I love this. What size tires are those?
    WorKinJoB likes this.
  15. Oct 20, 2017 at 12:44 PM
    imjustabill1970
    bill
    clarksville, tn
  16. Oct 20, 2017 at 1:04 PM
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    I got trail gear 1.5 inch spacers , seem to be doing just fine
  17. Oct 20, 2017 at 1:30 PM
    stun gun
    Aaronski
    Tacomas.
    265/75/16 cooper stt pro :fistbump:
    Dirty Harry[QUOTED] likes this.
  18. Oct 20, 2017 at 1:40 PM
    Dirty Harry
    Andrew
    SW Florida
    Very much want.
  19. Oct 20, 2017 at 1:59 PM
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    PM me with a price!
  20. Apr 17, 2020 at 11:53 PM
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    do you still recommend toytec over everything else? thanks
    stun gun[QUOTED] likes this.
