Wheels and tire question..
Discussion in 'Wheels & Tires' started by SNWMN209, Mar 27, 2010.
  1. Mar 27, 2010 at 10:34 PM
    SNWMN209
    SNWMN209 [OP] "Welp...see ya in the shit.."
    Knoxville, TN
    06 Prerunner, 3" Top Gun lift, Flux Capasitor
    3" Top Gunz lift Indash DVD Blacked out headlights K&N Intake Exhaust
    Hey guys and gals. I am about to get rid of the stock wheel and tire setup on the ole taco. Its an 06 prerunner (dc, lb) and i don't have the slightest clue on what size will fit and still give it that beefy look. It does have a 3" lift. Can someone PLEASE help. Thanks.
  2. Mar 27, 2010 at 10:44 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    16-17" wheel with 4.0 to 4.5 backspacing and negative offset between -10mm and -12mm. This will stick the wheels about 1/4 past the fender to give that tough i'm bad look. 285/70R17 or 285/75R16 tires. Yes they will rub slightly but minor trimming of plastic will be fine, so long as you don't ajust the caster too far back after alignment.
    There is your answer friend, and that's just a start cause we have an ocean of wheel and tire choices...
  3. Mar 28, 2010 at 12:16 AM
    stenyeart
    stenyeart Well-Known Member
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    3" Toytec Lift w/ AAL, TRD CAI, Leer 700 Series, Hypertech Speedo Calibrator, Locker Anytime Mod, LR UCA's, OEM Roof Rack, Satoshi grill with Devil Horns Emblem, USA Spec PA-15 Toy Ipod Integration, Redline Tuning Hood Struts and EZ Down Tailgate.
    Backspacing is the distance from the inside lip of the rim to the mounting surface of the rim. To measure this, you would put the rim face down, place a straight edge across the rim and measue from the straight edge to the mounting surface. Offset is the distance the mounting surface is from the center of the rim, positive being away from the vehicle and negative being towards the vehicle. Essentially they are the same spec for the rim, just measuring it different ways. Just an FYI. :)
  4. Mar 28, 2010 at 7:23 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Mostly correct. He does want rims with 4.0 to 4.5 backspacing, but the offset will be dependent on the rim width. Here's a handy chart to help with conversion (it's about halfway down the page).
    https://www.rsracing.com/tech-wheel.html
  5. Mar 28, 2010 at 9:36 AM
    SNWMN209
    Knoxville, TN
    lol thanks for the info. i had no idea i couldn't just "go buy a set of rims". well heres another question for ya. i really like the the black XD rims (rockstar, etc.) if i cant find those with the backspacing i need, then does anyone have any suggestions for a brand that is tacoma friendly?
  6. Mar 28, 2010 at 3:48 PM
    KPT
    09 Prerunner
    Most aftermarket wheels will have a version that has the backspacing you need.
    Several people on here have the rockstars.
  7. Mar 28, 2010 at 8:48 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    American racing and procomp make popular wheels for the taco. Check it out son
