Wheels and tires for my 09 Tacoma
Discussion in 'Wheels & Tires' started by jczelusniak, Apr 28, 2009.
  1. Apr 28, 2009 at 3:06 PM
    jczelusniak
    jczelusniak [OP] Member
    Columbus, OH
    09 Access Cab 2WD SR5
    Redi-lift lift kit
    I have a standard 5 lug wheel on my access cab 09 Tacoma with 215/70-15 tires on it. What size wheel and tire can I upgrade to without any suspension modification? I want a wider, taller tire.
  2. Apr 28, 2009 at 3:23 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Im running 235/55/18 in 18x8 +30mm offset wheel
    there is a thread around about 5-lug wheel/tire options
  3. Apr 29, 2009 at 9:53 AM
    jczelusniak
    Columbus, OH
    Redi-lift lift kit
    thanks for the reply. do you have a picture of the wheels? what do you have, a standard truck, prerunner, etc.?
    where did you get the fog lamps? How much?
  4. Apr 29, 2009 at 10:35 AM
    epa4wd
    Eduardo
    2019 SR
    Base Model Regular Cab. Fog Lamps are from ebay ($100 + S/H), they installed the same way as OEM, it includes wiring but no wiring instructions. I bought the OEM switch from toyota and installed it using that switch and modifying the included wiring so everything looks like factory. Wheels are from an X-Runner
    Pic:
  5. Apr 29, 2009 at 12:21 PM
    jczelusniak
    Columbus, OH
    Redi-lift lift kit
    I like what you did with a base model! amazing what tires and rims can do!
