Wheels and Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by elcuuh, Sep 11, 2020.
  1. Sep 11, 2020 at 11:45 AM
    elcuuh
    elcuuh [OP] Member
    I want to buy some bfg ko2 tires, 265/70/17 & some method wheels 17’’ x8.5. Will that fit or will there be a problem? I’ve read that x8.5 is too much.
  2. Sep 11, 2020 at 6:09 PM
    SmileyGuy
    SmileyGuy Well-Known Member
    Darrin
    Nova Scotia
    20 Tacoma Off Road Voodoo Blue DC SB TRD Premium CAN
    Just be aware that the new wheel offset is different from a stock wheel of +25 mm. The Methods vary but going to a 0 offset moves the rim out towards the curb. going from 7" wide to 8.5 wide plus offset can add up to removing front mud flaps. So if the new wheel has 0 offset the wheel moves out 1 inch plus half the difference of the new rim width 7" to 8.5", 1.5"/2= .75 inch
    Inside edge of rim went 1 inch to curb and back towards suspension .75 inch, over all difference .25 inch towards curb. Outer edge of rim move 1 inch with offset towards curb plus .75 inch of wider rim, over all 1.75" to curb. When looking a wheels just be aware of the offset and you can make a better choice.
    Compare different wheels and tire setups https://www.customwheeloffset.com/tire-wheel-backspacing-offset-calculators
    elcuuh[OP] and hiPSI like this.
