Wheels and Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Baybarton3434, Nov 5, 2021.
  1. Nov 5, 2021 at 9:32 PM
    Baybarton3434
    Baybarton3434 [OP] New Member
    Bailey
    2021 Black Tacoma SX
    3inch eibach stage one lift- Front 1.5inch ICON AAL- Rear Jba high caster uca’s
    So I have a 2021 Tacoma SX access cab, I put a 3 inch Eibach stage one lift in the front and paired it with the 1.5 inch ICON AAL in the rear. I also have the JBA high caster uca’s. I’m looking into buying the Summit Dakars in 17x9 with -25mm offset. I am wondering what is the biggest size tire I can fit with little to no trimming. I’m looking at BFG Ko2’s. Thanks in advance!
  2. Nov 5, 2021 at 9:36 PM
    Bishop84
    Bishop84 Well-Known Member
    It might sit really high in the front, but you can always add a 1" block to the rear to level it out. The access cabs tend to sit higher with lifts.
    You may as well shoot straight for 285/70R17, if you want big, 305's or 315's will fit the wider rims but you'll run into other issues with rubbing.
    Baybarton3434[OP] likes this.
