Wheels and tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toturnt, Nov 30, 2024.
  1. Nov 30, 2024 at 7:00 PM
    Toturnt
    Toturnt [OP] Member
    2008 Tacoma trd rwd
    Would a wheel that is 17x9 -25mm offset and a tire that is 265/70/r17 fit a stock Toyota Tacoma Without rubbing?
  2. Dec 2, 2024 at 5:52 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    -25 offset is a pretty "poked" wheel...most use positive or 0 offset on our trucks. and then you need to know the backspacing as well! Best thing to do is test fit a wheel on your truck to see if it will clear the brakes and UCA/LCA
