Wheels are stuck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DCJeeper, May 18, 2019.
  1. May 18, 2019 at 8:02 AM
    DCJeeper
    DCJeeper [OP] Well-Known Member
    Doing tire rotation now but can’t take the wheels off after removing the 6 wheel nuts. Wonder if dealer really did the rotation before. 2017 TRD OR. Any special steps before removing wheels? Waiting for answers BCCFFD68-688D-479E-A12D-98F38640FF6E.jpg
  2. May 18, 2019 at 8:03 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Kick the tire with your foot. It’s just surface rust holding it on.
    Spare Parts, SC4333, KOTOC79 and 13 others like this.
  3. May 18, 2019 at 8:04 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    With the wheel off the ground, hit the outer edge of your tire with the heel of your palm. Give it a solid pop. That force should be enough to break it loose
    Spare Parts and Skydvrr like this.
  4. May 18, 2019 at 8:05 AM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Give it a donkey kick to the top portion of the tire. She’ll break loose after a few of those.
    Spare Parts, OriginalMan and whatstcp like this.
  5. May 18, 2019 at 8:05 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Sometimes putting a bit of the truck weight on it can un seize it. Lower jack just a bit.
    TheGoat likes this.
  6. May 18, 2019 at 8:12 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    To provide real help; yes OP kick the tire at the edge.
    Especially in an area where you get a lot of moisture, rust tends to be the enemy here. Everything from sticky wheels to rusted frames.
    Where do you live? Some may suggest coating your frame as preventative.
  7. May 18, 2019 at 8:21 AM
    DCJeeper
    I kicked from inside towards outside and didn’t work. After viewing the video I’ll try to kick from outside like the guy did. I’m in VA, not too much snow but last year we had a lot of rain.
  8. May 18, 2019 at 8:23 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I smear a little grease on the mating surface on mine. Seems to help.
    You can get a bit of adhesion from the grease, but it's not as bad as without. Just make it a VERY thin coating.
  9. May 18, 2019 at 8:26 AM
    stealthmode
    Alberta
    If kicking the tire doesnt work get more leverage by placing a scrap 2x4 across the bottom edge of wheel and smash it with a 2x6 or 2x4 or BFH if you dont have scrap wood.
  10. May 18, 2019 at 8:34 AM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Maybe get your wife or a neighbor who can provide a more forceful kick.
    But seriously, give it hard heel kick to the left or right side.
  11. May 18, 2019 at 8:40 AM
    DCJeeper
    Yeah, finally kicked it loose from outside. I sprayed tiny amount of WD40 to the wheel lugs that might helped. Looks like I need to spay some PB blaster to remove the rust.FE722B37-EA0A-4185-9F39-3E9AF49113AA.jpg77E4BFF7-44BD-4658-81F9-9B30831C39E8.jpg
  12. May 18, 2019 at 8:48 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Just did my tire rotation earlier too
  13. May 18, 2019 at 8:49 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Some wd40 and a some kicks should break it loose.
  14. May 18, 2019 at 8:57 AM
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    Smear a light amount of clear silicone grease on the mating surface of the wheel. Use a very small amount because you dont want it drooling onto the brakes.
  15. May 18, 2019 at 9:14 AM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    NoOne likes this.
  16. May 18, 2019 at 10:33 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Tacomas are “Hub Centric” meaning that they use the center hub for rim/wheel alignment. This means this area is near a friction fit. A little rust and...stuck. Coat this area every time you take the wheels off with “anti-seize” and the problem becomes a non- issue. Some folks also lightly do the lugs on occasion as well to prevent seizing.
    mtip and whatstcp like this.
  17. May 18, 2019 at 10:36 AM
    tcjacado
    tcjacado Well-Known Member
  18. May 18, 2019 at 10:37 AM
    DCJeeper
    I applied a thin layer of Red N Tacky grease on the hub, hope it works.
    TheGoat and G.T. like this.
  19. May 18, 2019 at 11:09 AM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Next time have your bf or husband do the rotation. :rofl::D
    FHC likes this.
  20. May 18, 2019 at 11:14 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Just a touch of water displacement 40th formula inside each lug before you screw it on will also help stop your nuts from seizing on and you breaking a stud off.
