Wheels bowing inward (Alignment Issues)
Discussion in 'Suspension' started by cools20, Oct 8, 2012.
  1. Oct 8, 2012 at 3:31 PM
    cools20
    cools20 [OP] Well-Known Member
    Cooley
    Socal
    i mob dirty
    shits built
    Hey, so my wheels on my truck are bowing in and giving me uneven tire wear. My alignment seems fine, everything is straight. Im running an icon, total chaos mid travel set up with maxtrac spindles and 1.5 wheel spacers. Does anyone know what the problem could be? Thanks, Brandon
  2. Oct 8, 2012 at 3:49 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    "... alignment is fine..."
    No it's not. Too much negative camber.
    An alignment is more than just steering and toe.
  3. Oct 8, 2012 at 3:56 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Go get an alinement ;)
  4. Oct 8, 2012 at 4:00 PM
    cools20
    Cooley
    Socal
    i mob dirty
    shits built
    i jumped it a few weeks ago so i think the negative camber could of possibly came from that or i broke something by doing so? if i cranked my shock up to give it more height would you think that could help, its at the lowest point right now
  5. Oct 8, 2012 at 4:01 PM
    cools20
    Cooley
    Socal
    i mob dirty
    shits built
    got an alinement done last month at 4wheel...ha
  6. Oct 8, 2012 at 4:02 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    You don't fix your alinement by cranking your coil overs I say let some pre-load out and go get it alined. You may have bent the LCA or your frame rails but I doubt it unless you MEGA-HUCKED it ;)
  7. Oct 8, 2012 at 4:04 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Was that before or after you started having this problem? I can tell you from the pics this can be at least slightly corrected by your alinement cams
  8. Oct 8, 2012 at 4:16 PM
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    im surprised your still running the sway bar.
    take pics of the inside of the wheel to show people what else is goin on in there
  9. Oct 8, 2012 at 5:32 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Can you take some more pics of the lower controll arm? It looks bent.
