Wheels Down Towing Behind an RV
Discussion in 'Technical Chat' started by Calahan, May 30, 2021.
  1. May 30, 2021 at 6:53 PM
    Calahan
    Calahan [OP] New Member
    2007 Tacoma TRD
    Can a 2007 Tacoma 4x4 TRD be towed behind an RV with all 4 wheels on the road?
    If not, is it possible to set it up to be towed?
  2. May 31, 2021 at 7:15 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I think the manual says no. Can be done without damaging the truck with the rear driveshaft disconnected.
  3. May 31, 2021 at 7:17 PM
    Bishop84
    Bishop84 Well-Known Member
    Short answer is no, wrong vehicle.
    TnShooter likes this.
  4. May 31, 2021 at 7:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They make a device for this occasion.
    I personally don’t like the idea of having it on my truck. It’s another thing to fail.
    It’s called a driveshaft disconnect.
    It’s up to you if/what one you want.
    Here is on example
    https://www.remcodsc.com/coupling/
    Again, I’m not a fan of it.
    You’d be better off finding a vehicle that allows both the transmission and transfer case to be disconnected/neutral while in tow. (Like a Jeep?)
  5. Jun 1, 2021 at 6:51 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You can go to a Full Floating rear axle last I looked the cost for parts was Like $2500.00 if is that on the budget?
    Flat Towing makes backing up a real Pain drop the vehicle move as you need reconnect and go down the Road.
    Think of a trailer if your touring the country .
  6. Jun 1, 2021 at 7:03 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    This is interesting although I could not track Down a Price.
    If you want to flat Tow behind your RV I just don`t picture a fully tricked out 4x4 headed to King Of the Hammers.
    Might be something to explore if your touring the Country flat Towing s Rear Wheel Drive Vehicle.
    Depends How inclined one is carry your stock drive shaft and swap back.
    I understand your Misgivings about more to fail I feel that way About Automatic transmissions to the point i am afraid to even learn how to drive one.
  7. Jun 4, 2021 at 7:22 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    [QUOTE
    not indicated if U ? auto or manual
    in most cases its NOT recommended for extended towing hundreds / thousands o miles
    with an auto trans ignition on motor running.............................
    there are functions operating in the trans...............................in some cases would NOT be functional
    if the drive wheels were rotating
    long run the potential to cause issues or damage
  8. Jun 4, 2021 at 8:19 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Manual or auto? Manual just put it in neutral. Auto needs the driveshaft disconnected at the rear axle (4 bolts), relatively quick to do with an impact and a tarp to lay down on.
    I can see this being useful on technical trails where you pull on the cable to do a front dig :D Unfortunately all of the shift fork mechanism in the current design is low-hanging and exposed to contamination.
    TnShooter[QUOTED] likes this.
