Wheels of a 2001 Suburban fit a Tacoma?
Discussion in 'Wheels & Tires' started by John Hills, May 9, 2015.
  1. May 9, 2015 at 5:48 PM
    John Hills
    John Hills [OP] New Member
    JOHN
    2005 red tacomaTRD
    Will the wheels off a 2001 Suburban 4 wheel drive 16" 6 hole fit on a Toyota Tacoma 2Wd TRD Pre Runner 16" 6 hole? If not what kind of wheel adapter will I need?
  2. May 9, 2015 at 6:04 PM
    Red_Taco33
    Red_Taco33 Well-Known Member
    Upstate New York
    2021 TRD Off-Road MT
    You might be able to go onto Tirerack.com to see if they fit, but don't quote me on that. Also, go to a local shop and they can punch the specs into the computer and let ya know free of charge.
  3. May 9, 2015 at 6:08 PM
    Ripper
    Ripper Well-Known Member
    Why? Why would you diminish the value of your Toyota with Chevy parts???
  4. May 9, 2015 at 6:13 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    you are going to have a problem with the center bore on the chevy wheels, I believe they are smaller in diameter than standard Toyota 106.1...
  5. May 9, 2015 at 6:13 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    lug pattern is the same but the hub hole is too small I believe
    EDIT: yeah what bldegle2 said
  6. May 9, 2015 at 6:13 PM
    Ripper
    1/2 TON BLAZER/ JIMMY
    SUBURBAN/ TAHOE /YUKON 2X4 00-06 6x139.7
    Toyota Tacoma 4WD 6 lug 5.5 inch or 139.7mm Medium Offset
  7. May 9, 2015 at 6:19 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    I'm with the hub bore too small crowd
  8. May 9, 2015 at 6:20 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    bolt pattern matches, hub bores don't, the Chevy is 87.1, way too small to fit a Toyota hub...
  9. May 10, 2015 at 9:50 AM
    John Hills
    JOHN
    2005 red tacomaTRD
    Thanks! Everyone
  10. May 10, 2015 at 11:22 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Pretty sure its not possible due to center configuration of the wheel itself and not meaning the bolt pattern.
