Wheels on a tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by ajbradley3, Jul 12, 2014.
  1. Jul 12, 2014 at 4:12 PM
    ajbradley3
    ajbradley3 [OP] New Member
    Asher
    Russellville
    99 PreRunner SR5
    I am new to this thread and have tried searching without any luck.. I have recently purchased aftermarket wheels for my truck. The wheels came off of a chevy and I have always heard they fit but they do not due to the hub size is way different. Is there a spacer or an adapter of any sort to help with this? Thank you,
    Asher
  2. Jul 12, 2014 at 4:27 PM
    2013tacomaea
    2013tacomaea Member
    Edwin
    Kentucky
    2014 tacoma
    Stock
    What year is you truck? Is it a 2 or 4 wheel drive if it's a 05 or newer 4x4 here's a good baseline just look for (6x5.5 and 16x8/17x8) with a 0 offset and 4.0-4.5 backspacing. You can shy away the offset slightly meaning a -12 or so but I wouldn't chance it I'm not a 100% sure on that either someone else may know
  3. Jul 12, 2014 at 4:58 PM
    ajbradley3
    Asher
    Russellville
    99 PreRunner SR5
    My truck is a 99 prerunner and I already have bought the wheels is the bad thing
  4. Jul 14, 2014 at 10:53 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    the lug patterns are the same, but yah, it's the center bore that is off... Chevy center bore is smaller than yota, so the only option is to have it drilled out, though, i don't think i have ever heard of anyone doing that...
    i would think messing with the wheel that way could be sketch if not done correctly...
  5. Jul 14, 2014 at 10:55 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    oh wait.. just re-read that the wheels are aftermarket... the center bore should be universal enough to clear... since you already bought the wheels, go and do a test fit before mounting tires on them...
