Wheels question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shabutie, Feb 7, 2015.
  1. Feb 7, 2015 at 7:55 PM
    Shabutie
    Shabutie [OP] Well-Known Member
    Zach
    Fort Stewart
    2002 Toyota Tacoma Limited 4WD 4dr
    Can't seem to get a straight answer out of the wheels section of this forum and no amount of searching has brought anything solid up, main question is Can I run a 15" rim on my truck? I want 33x12.50r15 but not sure if its possible. 2002 DC 4x4. Thanks in advance.
  2. Feb 7, 2015 at 8:37 PM
    tacomatt602
    tacomatt602 Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    I'm no pro but from what I've read, you should be able to run 15s. It all depends on the wheel's backspacing and how much lift you have to see if your tires will rub against anything.
    If your truck is like my 5-lug, you should be able to run wheels as small as 14".
  3. Feb 7, 2015 at 8:44 PM
    Gimmick
    Gimmick Well-Known Member
    Anthony
    Canada
    2017 TRD Offroad DCSB
    I know 2nd gen 6 lug can only run 16s. Would def run 15s if possible
  4. Feb 7, 2015 at 8:47 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    You can. Wheelers offers a 15" rim specifically for use on 1st gens.
    I'm sure there are more that will fit but hard to tell without one in hand.
  5. Feb 7, 2015 at 9:16 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    ^^x2^^
    For sure 15's will work! But like mentioned already sometimes the calipers can be an issue, though I've never had an issue with caliper rubbing and I've used a few different 15 inch rims on my 1st gens.
  6. Feb 8, 2015 at 6:08 AM
    Shabutie
    Zach
    Fort Stewart
    Thanks everyone
    After I posted this I found a set of procomp rims that will work.
  7. Feb 8, 2015 at 3:01 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    What did it come with?
  8. Feb 8, 2015 at 3:08 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    SR5 trucks came with 15" wheels. TRD trucks use 16". I got both.
    One thing I did notice, my 4 x 4 with 15" wheels were taller than the 4 x 4 with 16" wheels, by just a tad. You have to have them side by side to see the difference.
    These are both gen 1 trucks.
  9. Feb 8, 2015 at 3:21 PM
    Brake Weight
    I was lead to believe that the latter of the 1st gens needed the 16" wheels to clear the brake rotors, not that the caliper was an issue. I've got 15" steelies on my '99 and needed a small spacer that I picked up at autozone to clear the caliper.
