Wheels+ spacer, made a bit of a hasty decision, some advice please.
Discussion in 'Wheels & Tires' started by Sunner, Apr 20, 2012.
  1. Apr 20, 2012 at 10:23 AM
    Sunner
    Sunner [OP] Well-Known Member
    I ordered 'type B' wheels for my 2nd gen last night from Wheelersoffroad. Type B have 4" BS so the description says that they will stick out a little, I also ordered 1.5" AP Hubcentric Wheel spacers. I wanted a wider looking stance but am afraid that I may have overdone it a bit. Will my wheels stick out 2"s each side now? What do you guys think?
  2. Apr 20, 2012 at 10:28 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    you might rub even with just the wheel.
    4.0 is slightly too little backspacing. PSU Taco 85 has 4.0 BS wheels and he had to cut a lot.
    If you add the spacers on to those, you won't even be able to turn out of your driveway.
  3. Apr 20, 2012 at 10:31 AM
    Sunner
    Dang, I might have to give both Wheelers and AP a call and switch back to the 4.5" Type A wheel and 1.25" spacer
  4. Apr 20, 2012 at 10:32 AM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    ^this^
  5. Apr 20, 2012 at 10:33 AM
    KPT
    09 Prerunner
    Can't run the spacer with those either, you'll rub incredibly bad. I was saying that PSU Taco rubbed with the 4.0 bs even without a spacer.
    If you want a wide stance you'll need to get 9" wide wheels with 4.5" BS, that about as wide as you can go on these trucks without a lot of cutting.
  6. Apr 20, 2012 at 10:35 AM
    Sunner
    Alright, Ill just stick with the wheels then and cancle the spacers, hopefully they can since I just placed it last night. Thanks for the help guys, made a bad decision, oh well.
  7. Apr 20, 2012 at 10:51 AM
    Sunner
    So I guess Ill be ordering a grill from you soon since Im not getting spacers now :thumbsup:
