Wheels, Spacers & Driving Habbits
Discussion in '2nd Gen. Tacomas (2005-2015)' started by malay4785, Nov 6, 2013.
  1. Nov 6, 2013 at 4:16 AM
    malay4785
    malay4785 [OP] Well-Known Member
    Malay
    New Jersey
    2012 SW Double Cab
    So I purchased some spidertrax a while back, and am in need of some new tires soon as my treads are starting to wear thin, so I was going to get new wheels and tires so I could go a little larger with the spidertrax while I wait on $$ for my lift.
    Current Setup:
    18" Factory Sport Double Spoke Wheels
    Factory 265x60/18" Duellers
    Thinking the SCS Stealth 6
    285x70/17"
    Would there be any rubbing issues with 1.25" Spacers? The wheels come with 4.3" of backspacing as well.
    Also, this is my DD, and my commute is 80 highway miles a day going on average 85mph, should I worry about the spacers not holding up at higher speeds? After getting the new wheels and tires, im sure i'll be a slightly more conservative driver, assuming people get out of my way.
    Thanks in advance.
  2. Nov 7, 2013 at 5:11 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Malay
    At stock height, you're not going to run 285s without pulling your hair out after making a few turns with either the stock wheels or with our wheels. Your best option is to run 265/70/17 until you get a 2.5-3" lift.
    Btw, with the Stealth 6, you will not need your adapters/spacers anymore. They're speced out to provide a nice stance that I'm sure you will be happy with.
