Wheels + Spacers Fitment
Discussion in 'Wheels & Tires' started by theTupper, Feb 24, 2012.
  1. Feb 24, 2012 at 2:59 PM
    theTupper
    theTupper [OP] White and Nerdy
    Jacob
    Raeford, NC
    '10 DCSB Off Road PreRunner
    Okay, so I've searched the threads and found MOST of the information I need.
    I'm adding 265/75/16s soon. My original plans were to add a set of spacers, too, but I've read that these tires won't fit the stock suspension with spacers added; that the spacers plus tires would require a lift.
    How much lift would be required to make this setup work?
    I've been debating a simple leveling kit (non TSB...so I'm thinking 5100s at .85)...would this yield enough additional clearance to run the spacers with these tires or would I need to go taller?
    TIA
  2. Feb 25, 2012 at 2:11 PM
    theTupper
    Jacob
    Raeford, NC
    Nobody? Thanks anyway!
  3. Feb 25, 2012 at 5:23 PM
    valon5150
    valon5150 Well-Known Member
    Steven
    redding
    01 taco turd
    all pro lift, 33s, home made sliders, bumpers, skids
    I don't know much about the 2nd gens tire fitment. But A guy I worked with had an 06 or maybe it was 07 access cab, 2.7 4x4 with stock steel 16's and he ran 265/75/16 KM2's. and he had machined his own leveling spacer that was supposed to be the same as a revtek, think his was 2 or 2.5 not the full 3. He had no rubbing issues. Don't know about completely stock though...well that might not have been usefull to you at all but i figured i'd throw in my .02
  4. Feb 25, 2012 at 5:26 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    What kind of rims do you have?
  5. Feb 25, 2012 at 8:17 PM
    theTupper
    Jacob
    Raeford, NC
    Stock 16s.
    I know the tires will fit WITHOUT the spacers...I'm just curious to know if they will fit WITH the spacers if I add a leveling kit.
  6. Feb 25, 2012 at 8:27 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    With spacers the tires will most likely hit on the mudflaps if you have them on , that won't really change by lifting .
  7. Feb 25, 2012 at 9:13 PM
    theTupper
    Jacob
    Raeford, NC
    So, the mudflaps are the only issue? If that's true, I'm golden as they're already history. :)
