Wheels/Tires advice
Discussion in 'Wheels & Tires' started by Pster, Mar 7, 2009.
  1. Mar 7, 2009 at 3:32 PM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    What is a good aftermarket wheel and tire size without doing any lifts or anything? I like the blacked out wheel look, but I really don't want to raise the height of my tacomania any more.......?
  2. Mar 7, 2009 at 3:37 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Theres tons of options with wheels/tires what are you looking to get out of it? Better ride on road/off road? better performace on road/off road?
  3. Mar 8, 2009 at 10:32 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I really like the ride of my 4x4 SR5...I think I am looking for something that has a more aggressive look or will provide an even better ride on pavement.
  4. Mar 8, 2009 at 4:57 PM
    rmb_crew
    Well you could look for something like an AT and if you want the same size just stay with 265's but if you want you can make them wider also.
  5. Mar 8, 2009 at 5:08 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Thanks! Think what I may be interested in is a +1 or +2 and a little wider than the OEM.
  6. Mar 8, 2009 at 5:12 PM
    rmb_crew
    Yeah that would be a good look. Definitely wider. A +1 should be a good size. i think if you go to a +2 you might need a lift.
