Wheels & Tires for 3 inch suspension lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eblacky1457, Sep 2, 2015.
  1. Sep 2, 2015 at 12:05 PM
    eblacky1457
    eblacky1457 [OP] New Member
    Evan
    2018 Tacoma TRD Sport
    I am curious as to what size wheels and tires I would be able to fit with a Rough Country 3 inch suspension lift. I want the truck to be completely level and the tires to stick out a little bit.
    I want to put Fuel Assaults wrapped with Nitto Mud Grapplers.
    Here is picture of the stance I would want. Thanks for the input/comments .
    If this picture is just a leveling kit that would be perfect.
  2. Sep 2, 2015 at 12:12 PM
    Connormc11
    Connormc11 Jangler
    Connor
    Norfolk VA
    2010 DCSB TRD-Offroad
    if you want 16" wheels 285/75r16
    if you want 17" wheels 285/70r17
    basically a 33" tire is the biggest you can go. make sure you get wheels with the right backspacing so dont have issues with the stock UCAs (4.5" is what i think most people recommend). even with 3" lift, if you want to run 33s the mud flaps need to go and some trimming will probably be needed if you plan to wheel it at all.
  3. Sep 2, 2015 at 12:16 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    ^This.
    I'm running 285/75/16s. 285s look better IMHO with a 3" lift. Depending on your driving style and needs, be prepared to cut a little more than the inner fenders.
  4. Sep 2, 2015 at 12:18 PM
    Sexum
    Sexum Well-Known Member
    Steven
    Pensacola, Florida
    '05 SWB DCSB Trd Sport
    33 inch Trail Grapplers 18x9 Fuel Hostages 30 inch 4d Optics Lightbar Weather tech floor liner Magna flow dual exhaust
    I have 285/65/18 trail grapplers with 18x9 hostages -12 offset. I removed the mud flaps and trimmed the plastic, and I no longer have rubbing issues. I am running the 3 inch RC.
  5. Sep 2, 2015 at 12:23 PM
    eblacky1457
    Evan
    Thanks everyone.
    I think I just want to level it and get the Tire/Wheel set up I mentioned. However when I go to order I dont know exactly what numbers and all that to select.
    Basically I want my truck to look like that picture I posted but with different wheels and tires
