Wheels/ Tires question
Discussion in 'Wheels & Tires' started by ldanny, Feb 11, 2009.
  1. Feb 11, 2009 at 8:32 PM
    ldanny
    ldanny [OP] Well-Known Member
    I have a 07 Sport, I was wondering if 16inch with a 30offset will fit without doing anything to the calipers? And what is the max tire size i can run without a lift.
    Thanks
  2. Mar 24, 2009 at 4:40 PM
    toyotacoma
    toyotacoma Member
    Fort Collins
    07 Prerunner SR5
    Kenwood Excelon X-592 Custom TRD Badges
  3. Mar 24, 2009 at 4:47 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    New Bern NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    I'm not sure about the -30mm offset. I know that will push the wheel out from caliper. This link will help you understand wheel measurements - https://www.rsracing.com/tech-wheel.html#fitting
    As far as the largest wheel you can run w/o a lift is a 265/75-16
