Wheelwell trim to fit LT285/70R17
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bjmoose, Sep 14, 2010.
  1. Sep 14, 2010 at 9:22 PM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I spent some time on a Toyota dealer lot this evening, and taking spy photos of a 2010 Access Cab lifted and modified by a major nationwide 4 wheel parts chain to be sold off the dealer's lot. This truck has a 3" pro-comp coilover spring suspension lift, and ProComp Extreme ATs in LT285/70R17. Sorry, I didn't note which wheels they're using so we could research the backspacing.
    I wanted to capture the extensive trim work that was done to fit the tires without rubbing. All photos are of the driver's side wheelwell. On all photos, you can click through to the gallery view and see the 1024x768 larger photo.
    From outside, you don't see much. But when you look inside the wheelwell, and know what to look for, you can see how much cutting they've done, and it's quite a bit.
    Starting below the front bumper, from the outside, it all looks pretty stock:
    But, if we flip around to the other side, you can see they've cut a little off the outer fender. We'll get a better look at the wheelwell trimming itself in the next pic...
    Here, red lines accentuate all the *missing* plastic. A lot has been removed from the front wheelwell!
    And here's about the same view, but accentuating the cut line itself. See how nice and stock it looks? We didn't *really* take a scissors to it ;-) But from this perspective on a stocker, you wouldn't be able to look out the front grille.
    Here, we shift perspectives and are now looking at the rear of the wheelwell. Plastic trimming isn't that extensive, but they've trimmed the cab mount (part of the frame) and covered the cut by welding, grinding, and painting a small plate over the opening.
    Now this photo is interesting for what has NOT been cut! I've sketched in green lines over some high-profile wheelwell pieces you might expect to have to trim, but they've been left untouched. And you can see the outer fender is completely stock as well.
  2. Sep 14, 2010 at 9:24 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Haha, that's nothing :anonymous:
  3. Sep 14, 2010 at 9:30 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Now I know actual tire sizes and wheel offsets will vary. But I hereby and forever more take any and all claims that "I'm running 285/70R17 (or 285/75R16) tires, and I didn't trim and I'm not rubbing" with a large grain of salt for any vehicle that actually turns lock to lock or goes over any speedbumps. As always on the boards, YMMV, there's only one at this price, and objects in the mirror are closer than they appear. ;-)
  4. Sep 14, 2010 at 9:33 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    not to bad they did what they had to do so some one doesnt buy it and keep comming back to the dealer every time a tire rubs? is it 4x4?
  5. Sep 14, 2010 at 9:34 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I tend to agree actually. It's not that bad, if you know those are the meats you want to carry and you're willing to take a fairly heavy hand with the snips and actually get out the grinder and welder.:cool:
    But if you really want to leave those wheelwells stock, a smaller tire size might suit better.:D
  6. Sep 14, 2010 at 9:34 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah, 4x4 Access Cab V6.
  7. Sep 14, 2010 at 9:35 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Haha, yea I had to trim a very tiny bit when I was running 285/75/16's. I had to cut a lot to fit the 315/75/16's I have on their now.
    So long as you can't see anything from the outside than trimming doesn't really hurt anything.
  8. Sep 14, 2010 at 9:36 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Looks like mine
  9. Sep 14, 2010 at 9:52 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    looks like mine also. i still rubbed my cab-mount tho...
  10. Sep 14, 2010 at 9:57 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You still rubbed the cab mount even AFTER you cut some of it away with a grinder? :eek:
    What size tire/wheel and what wheel offset are you running??
  11. Sep 14, 2010 at 10:01 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Are you running 255/85/16 ?
  12. Sep 14, 2010 at 10:13 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    Ooops... missed the pic with the chopped mounts :D
