When a/c is off and every time windshield operates truck vibrates.
Discussion in '1st Gen. Tacomas (1995-2004)' started by firstacom, Aug 30, 2014.
  1. Aug 30, 2014 at 5:34 AM
    firstacom
    firstacom [OP] New Member
    florida
    Hello out there, I would like some help. When my a/c is turned off and get to a stop and every time my windshield wipers slides up and down, the truck vibrate a little more than usual, I feel like an rpm drop. Any help will be apreciated, thanks.:
  2. Aug 30, 2014 at 6:02 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Try cleaning the IACV. It's under the throttle body.
  3. Aug 30, 2014 at 6:13 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Out of balance wiper blades?
  4. Aug 30, 2014 at 7:43 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    It is a very known problem with an automatic transmission. Clean IAC, clean MAF, change intake temp sensor, change coolant temp sensor, make sure you have a clean air filter, check for vacuum leaks, make sure you have no CEL codes.
    How many miles are on the truck, have you checked compression on all cylinders and have the valve pucks ever be checked for clearance? Also, change the plugs and wires if you havent already.
