When $BTC breaks $125,000 its value will exceed that of all the U.S. currency in circulation...
Discussion in 'Stocks & Investments' started by kairo, Oct 6, 2020.
  1. May 24, 2022 at 5:29 PM
    kairo
    kairo [OP] >_>
    Nor Nev
    '20 OR DCLB Quicksand
    I need to enroll him in the kairo school of vague but tangentially correct whataboutism arguing
    98tacoma27 and jandrews[QUOTED] like this.
  2. May 24, 2022 at 5:31 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Yep. The strongest shape for 1 atmosphere loads. After about 100' under water the sphere actually becomes stronger. It's why subs are elongated spheres and not triangular.
    98tacoma27 and not_nick like this.
  3. May 24, 2022 at 5:35 PM
    theesotericone
    Bishop CA
    Yep. I might still have a copy of Efficient Carpenter stashed in storage.
    In the past 5 years I've worked with a lot of "journeyman" carpenters that can't figure out how to make a seat cut. That's after I do the math and give them the numbers. That used to be higher end apprentice knowledge. lol
    98tacoma27 likes this.
  4. May 24, 2022 at 5:38 PM
    jandrews
    '09 FourDubDee TRD OR
    "You mean they're not pre-cut?"
    We are slowly moving toward housing IKEA style - just assemble the pieces.
    That's not entirely a bad thing from cost/efficiency standpoints, but there are tradeoffs, and some things people like about traditional construction go away with that format.
  5. May 24, 2022 at 5:38 PM
    kairo
    kairo [OP] >_>
    Nor Nev
    Tell us the 22' beam (or whatever the length was) story again, grandpa!
  6. May 24, 2022 at 5:38 PM
    kairo
    kairo [OP] >_>
    Nor Nev
    Sears had that shit figured out in the 50's
  7. May 24, 2022 at 5:39 PM
    jandrews
  8. May 24, 2022 at 5:40 PM
    kairo
    kairo [OP] >_>
    Nor Nev
  9. May 24, 2022 at 5:41 PM
    theesotericone
    Bishop CA
    For sure. It started 20 years ago with trusses becoming the go to. In 20 more years I see SIP kit homes being the go to. There will always be a need for skilled carpenters for very high end stuff though. Some of the homes I've worked on are pretty amazing. One thing those all have in common? Not a single pre-fabbed truss anywhere in the build.
  10. May 24, 2022 at 5:42 PM
    kairo
    kairo [OP] >_>
    Nor Nev
    Rich people can afford better homes. Hmmm. I'm going to make note of this economic revelation
  11. May 24, 2022 at 5:47 PM
    theesotericone
    Bishop CA
    Better in many ways. The house that had the 28' beam problem was so sick. Looked over the ocean. The second and third floors had a 3/4 rap around deck. That was all glass on both floors. Cool right? Till you pressed a button and that glass all folded in like an acordian to provide an open air home. So fucking rad. We had 1/16" tolerances for that entire opening. We nailed it and the glass install company nailed there work because of it. They functioned flawlessly. You could have a set-up just like that for about $350K. lol
  12. May 24, 2022 at 5:49 PM
    jandrews
    Mines a stick built custom done in 2003. Crawlspace. Floor beams are stacked on the sill plates and piers, tripled 2x12s. Floor joists are 2x6, stacked and toenailed on the beams. Several rooms have cathedral ceilings, well blocked and braced.
    I told the wife we're never, ever selling the place because we'd never be able to find another.
  13. May 24, 2022 at 5:52 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Can’t be
  14. May 24, 2022 at 5:52 PM
    jandrews
    Fucking...the first time you see a finish carpenter go to 1/64th you gain a whole new respect for that shit.
  15. May 24, 2022 at 5:55 PM
    jandrews
    Also, question: How do you deal with dimensional stability on a tolerance that tight in framing? Like isn't the timber movement with temp and humidity changes going to exceed 1/16"?
  16. May 24, 2022 at 6:02 PM
    kairo
    kairo [OP] >_>
    Nor Nev
    I'm pretty sure my entire house was built by day laborers in a single Friday. I'm lucky if anything has 16" of tolerance
  17. May 24, 2022 at 6:03 PM
    kairo
    kairo [OP] >_>
    Nor Nev
    Frame it with dry aged oak and hickory. Much strong, very tolerance
    98tacoma27 and Iwilltaco like this.
  18. May 24, 2022 at 6:06 PM
    theesotericone
    Bishop CA
    Good question. The entire home was built with LVL and LSL's. Because it's man made it is perfectly straight and uniform in size. Because of the glues and bonding method used to make them they don't swell or shrink. It was the most mathematically perfect house I've ever built.
  19. May 24, 2022 at 6:10 PM
    theesotericone
    Bishop CA
    Nope. Oak, hickory and walnut are super hard to work with because they shrink and twist. The harder a wood the tighter it's grain. The tighter it's grain the more it distorts. It's why Doug Fir is the go to framing lumber of choice. If I had to frame with Oak my homes would look a lot like all the NE barns from the 1800's. The craftsmanship was amazing but after a few years they start to fall apart becuase? OAK. lol
  20. May 24, 2022 at 6:11 PM
    kairo
    kairo [OP] >_>
    Nor Nev
    Can confirm. Grandparents had an oak mantle that finally split after about 50 years
