when corning in 4x4 it feels like the the cv joint is binding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jlf4x4, Jul 3, 2017.
  1. Jul 3, 2017 at 1:22 PM
    jlf4x4
    jlf4x4 [OP] Member
    when taking a sharp corner while in 4x4 it feels like the cv joint is binding or I have square tires? Has anyone else had this problem 2010 taco?
  2. Jul 3, 2017 at 1:24 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    on dry pavement this is normal, no center diff on these
    RogueTRD likes this.
  3. Jul 3, 2017 at 1:25 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    what he said...
    tacoma is a truck, with a selectable transfer case without a center diff. It is not an AWD car.
  4. Jul 3, 2017 at 1:35 PM
    jlf4x4
    jlf4x4 [OP] Member
    I only use 4x4 in the snow ?
  5. Jul 3, 2017 at 1:37 PM
    jlf4x4
    jlf4x4 [OP] Member
    I had a 1994 Bronco u joints that did the same but not as bad as the taco. I did have to replace the u joints on the Bronco once
  6. Jul 3, 2017 at 1:44 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    This is normal. Carry on.
  7. Jul 3, 2017 at 1:44 PM
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    4lo is for slippery/wet/uneven/low traction.
  8. Jul 3, 2017 at 1:45 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    If the tires have too much traction (bare pavement, slick rock) you will bind while in 4wd
  9. Jul 3, 2017 at 1:47 PM
    jlf4x4
    jlf4x4 [OP] Member
    ok thanks guys
  10. Jul 3, 2017 at 2:14 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    NO, it's not normal, and don't carry on. NEVER operate in 4X4 on dry hard surfaces on or off road. The truck isn't designed to do so and if you carry on you'll break expensive parts. You have already damaged them. Just because they ain't broke yet doesn't mean damage hasn't happened.
  11. Jul 3, 2017 at 2:16 PM
    Bebop
    Nick
    I didn't condone driving on concrete in 4wd but the sensation of the steering binding is a normal feel.
  12. Jul 3, 2017 at 2:22 PM
    jlf4x4
    jlf4x4 [OP] Member
    I don't drive in 4x4 on dry street surfices only in snow or dirt. thanks for your input!
  13. Jul 3, 2017 at 4:06 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    How do you know he damaged anything? It's fairly common to feel some binding on any surface. I've felt my tires hop in the snow during sharp cornering.
  14. Jul 3, 2017 at 8:54 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    yup, just damaged the tires ever so slightly...
  15. Jul 3, 2017 at 8:57 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Damn my truck must be totalled
    Like for the last 9 years
  16. Jul 3, 2017 at 8:59 PM
    OZ-T
    Peter North
    British Columbia
    Even on snow at full or close to full lock you may experience that binding feeling , try to open the steering and increase the turning radius if possible
  17. Jul 4, 2017 at 8:31 AM
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    You're saying only run 4x on wet surfaces?
