When did Toyota change the spare tire elevator type?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, May 13, 2015.
  1. May 13, 2015 at 9:00 PM
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    My '09 has a cable style elevator. I've noticed that on the newer trucks ('13?) they have a chain type mechanism.
    Do I have that right?
    Why did they change it?
  2. May 14, 2015 at 1:37 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The chain type was the original method used years ago. My 1980 4X4 had a chain hoist for the spare. Then they went to the crappy cable type ( not sure when ), but they had issues with the cable getting corroded and the end piece coming off dropping the spare or getting so bad you couldn't get the spare to drop.
    Back to the reliable chain system I think in 2011 or 2012 ( my 12 has a chain ). It also pays to get under and drop the spare occasionally and grease the mechanism.
    Crom[OP] likes this.
  3. May 14, 2015 at 2:45 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Crom[QUOTED][OP] likes this.
  4. May 14, 2015 at 2:51 AM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    I have an 06 that just got done with the frame replacement. They also replaced the cable with the chain
    R0dzilla75 and Crom[OP] like this.
  5. May 14, 2015 at 6:50 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks for all the info. Mine is in really good shape, no corrosion detected and is working properly. If it becomes a problem, I'll swap it out for the chain one. Thanks.
  6. May 14, 2015 at 9:22 AM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Damn I hope they do that to my 05! They said it was part of the replacement but didn't specify it would be the chain instead of the cable.
  7. May 14, 2015 at 9:24 AM
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    You Canadians just may be on to something with this fluid film. Going to pick up a case and go to town when I get my rig back. That new frame will hopefully stay new for a long time.
  8. May 14, 2015 at 9:27 AM
    unlewser
    unlewser Well-Known Member
    Tempe, AZ
    those with a chain, the chain always falls through the rim center cap hole and dangles. Then rattles anytime i hit a bump. Anyone else have this problem?
    I also flipped the spare so the valve stem points down so I can check/fill up easier.
  9. May 14, 2015 at 10:47 AM
    BassMaster06
    Dan
    South Carolina
    I'm pretty sure they will. All the newer tacomas are getting them. I'd call your dealership and see what they have planned, and request to get the chain.
    R0dzilla75[QUOTED] likes this.
  10. May 14, 2015 at 11:02 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If you already have the cable tire hanger and want to swap to the chain hanger, or vice versa, the holes are not spaced the same for the 2 hangers. The holes are narrower on one, closer together, than on the other. I wanted to go from cable to chain only to find out I would have to drill 2 holes in the frame brace for it to line up. The chain started in 2012 and people getting frame replacements that use chain when they used to have cable tells me the frames being used are of the 2012 and up configuration. That being said, anyone interested in a chain hanger with the oem lock? I just stayed with my cable one instead of drilling the frame to make it work.
  11. May 15, 2015 at 5:36 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It isn't a "problem". That is the nature of a chain.
  12. May 15, 2015 at 5:57 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    R0dzilla75 likes this.
  13. May 15, 2015 at 6:04 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^I was thinking more:
  14. May 16, 2015 at 7:20 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Hilarious!
  15. May 16, 2015 at 7:41 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Just you wait until the Grand Nagus hears of this.
  16. May 16, 2015 at 8:14 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    My 1983 22RE had a chain.
  17. May 16, 2015 at 9:01 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    2012 here, chain.
    My '01 w/ new frame they replaced with a cable. Hmm.
    That's your leafs. Or engine ticking. Or interior panels rattling. Or rear slider rattling.
