When do I need to replace the water pump?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cfrain, Aug 18, 2016.
  1. Aug 18, 2016 at 1:07 PM
    cfrain
    cfrain [OP] Member
    2000 Dark Green Tacoma
    none
    I just bought a 2000 Tacoma (manual, 4x4, V6, 107,000 miles). It seems that water is very slowly dripping through the skid plate holes. After looking for details online, it seems this might mean I need to replace the water pump.
    If it is the water pump going bad, how quickly do I need to replace it? I'd like to be able to wait at least a few weeks to save money for the repair.
    Thanks.
  2. Aug 18, 2016 at 1:56 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    If it's the water pump and you can't afford to change it right away. You better check your radiator level and or coolant resevior. When mine started leaking I would pour a half of a bottle of coolant in and by morning it was empty and all over the ground. Usually when the water pump starts to fail it's best to change everything. Like Timing belt, thermostat and all that good stuff. At least that's what I did w/ mine. Good luck OP! The water pump is a very important part.
    cfrain[QUOTED][OP] likes this.
  3. Aug 18, 2016 at 2:34 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    I would do a more detailed inspection and make sure it is the water pump. Take the skid plates off and take a looksee. Also check the radiator tanks. Both upper and bottom tanks. They are known to get hairline cracks that are barely noticeable. Usually on the top tank though.
    And I'd like to say it should last that long before you get to the repair, but you never know. It could go out tomorrow, or could last months. Of you really gotta wait, just take it easy, and keep a VERY close eye on the temp gauge. Like one eye on the road and the other on that gauge. As soon as you notice it creeping up, pull over and shut her down. Remmber that the temp gauge is not that accurate and the slightest increase in temp will mean it's already overheating. In the red it's too late.
    cfrain[OP] likes this.
  4. Aug 18, 2016 at 2:42 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Make sure you can find the leak before replacing any parts. I blew a headgasket and it was leaking water externally and running off of the skid so you never know what the cause could be until you find it.
  5. Aug 18, 2016 at 3:00 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Pressure tester is your friend .
    Help you find the leak in a short time
  6. Aug 19, 2016 at 9:32 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    The best time to replace the water pump is just before it goes belly-up ;) !
  7. Aug 19, 2016 at 2:11 PM
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    Like mentioned above, take off the skid plate and see if you can see where it's leaking. Does the truck have A/C? is it leaking "water" when your driving or just sitting and shut off?
  8. Aug 19, 2016 at 2:42 PM
    cfrain
    cfrain [OP] Member
    none
    It appears that I overreacted. After observing the underside of the truck and my last few parking spaces, it seems that I was just seeing water that had pooled in the skidplate from the ac.
    Thanks for all the feedback.
  9. Aug 19, 2016 at 3:58 PM
    NightProwler
    Harlan
    Maricopa, Az
    You sure about that? I thought the drain was located above the ground, not above the skid plate, and at the firewall...
    Not only that, I assumed you were losing coolant. Is it full?
  10. Aug 19, 2016 at 4:01 PM
    Wulf
    rock raisin
    T
    yeah, mine drips onto the pass frame rail which is past the edge of the skid plate.
    @OP have you checked your coolant level? edit: if you do so make sure the engine has been off for a long time and the radiator is cool to the touch before removing the cap!!!!!!
  11. Aug 19, 2016 at 4:01 PM
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    coolant is pink and smells chemically, a/c condensation is clear and odorless (or maybe musty smelling if your a/c has gone moldy on you)
