When Do You “Locker” Up?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by therealprotaco, Jan 17, 2020.
  1. Jan 17, 2020 at 5:37 PM
    therealprotaco
    therealprotaco [OP] Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    When is everyone engaging your rear (and front if equipped) locker?
    I have always waited until right before an obstacle that is going to require 4L. Sometimes I’m already in 4L when I get there but generally I don’t actually hit the lockers until the hill climb, rock pit, rock shelf, mud bog, or whatever else I might get stuck doing.
    I have seen other people do that as well but also people who wait to hit the locker until they aren’t able to get all the way through the obstacle. This never made any sense to me as sometimes the momentum you would have gained by previously engaging the locker would have kept you from slipping/spinning or worse, getting stuck, in the first place.
    hi4x4, rubiconjp and Mully like this.
  2. Jan 17, 2020 at 5:50 PM
    KGTaco
    KGTaco Well-Known Member
    Southern California
    2019 Tacoma TRD 4x4 Offroad
    King 3.0/Bumps/Deavers/33s
    Most people enjoy the challenge with open diff, hence why they try that way first.
    Those who lock up prior like you, will most likely break less stuff because you aren't tryna plow thru it with momentum and open diffs
  3. Jan 17, 2020 at 5:56 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    ATRAC is good to get me through almost everything and the locker is mostly there for when I get or plan on being stuck.
  4. Jan 17, 2020 at 5:57 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
  5. Jan 17, 2020 at 5:57 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    LOL I thought off road owners always engage their lockers because they spent their money wisely on a truck that has lockers!? :rofl::rofl::rofl::rofl:
    hi4x4, Raybandz18, Hal_XIII and 7 others like this.
  6. Jan 17, 2020 at 6:00 PM
    Stocklocker
    17TRDORDCSBAT
    Is this locker talk?
    AKGSD and therealprotaco[OP] like this.
  7. Jan 17, 2020 at 6:02 PM
    Dr. Emmett Brown
    I just assumed y'all drove on the road 24/7 fully locked and in 4wd!
  8. Jan 17, 2020 at 6:02 PM
    Shellshock
    Iowa
    Almost never. I keep ATRAC turned on. If that doesn’t get me through, then I’ll turn on the locker
  9. Jan 17, 2020 at 6:03 PM
    therealprotaco
    Gilbert, AZ
    With the BS electronics on these things I’d be too scared to try that....
  10. Jan 17, 2020 at 6:05 PM
    Dr. Emmett Brown
    Haha.
    In all seriousness 90% of the time if not more 4lo will get you by. So I would say to not turn it on until you need to or if you can proactively see an obstacle in which you leave the ground on one or more wheels
    protacodan and Big tall dave like this.
  11. Jan 17, 2020 at 6:08 PM
    Stocklocker
    17TRDORDCSBAT
    I use my locker occasionally in snowy / icy conditions, when I want to make sure the truck goes straight forward, with no wheel spin. Times when I do not want the rear end to kick out on a climb, or spin at all.
    MQQSE, Truks4elk, Captqc and 3 others like this.
  12. Jan 17, 2020 at 6:13 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    A locker will likely increase the chance of your rear kicking out in slick off camber instances. With both tires spinning at the same rate you are essentially floating and gravity will take over.
    JimboAnz, honda50r, synaps3 and 7 others like this.
  13. Jan 17, 2020 at 6:16 PM
    Kwisak
    Kwisak Well-Known Member
    Jon
    Arizona
    2024 Tundra Limited off-road 2018 Inferno Tacoma Off Road MT
    Pro grill Joying radio with wireless car play Hood decal Bed decal Pro skid Pro wheels 285/70/17 Sliders Blackout emblems Pro exhaust Pro intake Painted engine cover Ditch lights Tint Tacoma letters glove box Off-road wether tech inserts Lock box console Blackvue Orange trim Orange inserts Katzskin Weather tech Bed mat Hilift Tire locks Extra switch Rotopax Fox 2.5 fronts with 700lbs Kings Fox 2.0 rears with resi Icon rxt springs Icon Delta UCAs Meso side markers Meso gashole On order —— Avid bed rack SSO bumper Morimoto headlights and fogs Meso map lights and done light
    After I failed once, or maybe twice. So far that has been mud and snow
    Shellshock likes this.
  14. Jan 17, 2020 at 6:16 PM
    Buckfat
    Buckfat Well-Known Member
    N GA
    2019 DCSB OR
    Wish i could lock it in 4h!
  15. Jan 17, 2020 at 6:22 PM
    Stocklocker
    17TRDORDCSBAT
    I’ve done 1000kms of winter driving and this is not my experience at very slow speeds. The locker prevents a tire from spinning, polishing the ice, before the traction control “catches” the tire. I am only describing situations where you want the truck to crawl straight forward.
    MQQSE and Truks4elk like this.
  16. Jan 17, 2020 at 6:23 PM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    In my Tacoma sometimes until I need it other time flick it on until I’m done wheeling.
    in the tj I put her in low and lock the rear immediately off pavement every time, the limited slip has been known to eat ring and pinions upon failure.
  17. Jan 17, 2020 at 6:24 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Before I think Ill need it, that way its actually engaged and I dont have to worry about the mechanism lining up once Im already stuck.
    Or before I wanna drift some dirt roads (2nd gen anything locker FTW) :D
  18. Jan 17, 2020 at 6:27 PM
    bijick
    E
    Stl
    a locker would force wheel spin in that situation, if one tire is spinning the other is also. Traction control can’t defeat a locker either in my experiences.
  19. Jan 17, 2020 at 6:29 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I wait till after I'm stuck. I wanna know each of different limits the truck has. 4h 4l Trac off lsd etc. If I'm stuck stuck I'll winch out. I like the slow technical approach. Any yahoo can stand on the throttle and blow through some sections.
    hi4x4, TacoFMS and t0nyvalenzuela like this.
  20. Jan 17, 2020 at 6:40 PM
    Stocklocker
    17TRDORDCSBAT
    Not in my experience. Might be the Canadian Ice.
    MQQSE, Truks4elk, SR-71A and 2 others like this.
