when do you change dif. oil?
Discussion in 'New Members' started by calvin b, Jul 17, 2013.
  1. Jul 17, 2013 at 10:56 AM
    calvin b
    calvin b [OP] New Member
    calvin
    colorado
    06 trd sport sr5
    never changed front or rear differential oil or transfer case on my tacoma before Am i in for alot of work? The dealers and shops want 300_-400 bucks or more to do these three things. I am pretty handy with tools ,and got a lot of them. I was ask if the oil is synthetic, so i said , doen't know. If somebody could explain in layman terms I would be very grateful. Any info on chassis lubrication would be great too. Do I need any special tools? Thanks calvin b
  2. Jul 17, 2013 at 11:10 AM
    Large
    Large Red
    I think recommended at 15k intervals (rear diff) if you tow, 30k if not and 60k for the front and t-case, I know myself and a lot of other members just do all 3 at 15k intervals, it's not real hard, just pick a good 75w 85 sythetic oil
  3. Jul 17, 2013 at 4:10 PM
    fxlbalto
    fxlbalto Member
    There is a thread somewhere on here that shows the whole process. It is very easy.....
  4. Jul 17, 2013 at 4:19 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Just like changing your oil. There is a drain and fill plug for each.
    Just make sure you verify that the fill plug isn't stuck before you drain.
    I think I used a 15/16" wrench on the rear axle, and TC plugs.
    The tranny and front axle might use a different size (14mm?).
    You'll need a 'grease gun' to lube the zerks on the drivetrain.
    Use the fluids and grease that are recommended in your owners manual.
  5. Jul 17, 2013 at 4:23 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Op has older sport model.
    I believe they chatter with syn.
    Shouldn't he be using a conventional gl5 with equatorq in the rear end?
    Special tools..... Does the 2nd gen front end require the 10mm Allen head?
    I've never popped the drain or fill off a 2nd gen, and its been yrs (2002) since I've done this on a 1st gen.
    If so, I suggest a 10mm Allen head SOCKET..... It fits a 3/8 ratchet and ends in an Allen wrench type tip and makes life easier if second gens indeed use these. (anyone verify size or other type of hardware?)
  6. Jul 17, 2013 at 4:29 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Don't forget a transfer hand pump..... To pump fluid from the new bottles into the gear boxes.
