When do you change your fluids?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TopDawg1776, Apr 20, 2018.
  1. Apr 20, 2018 at 8:30 AM
    TopDawg1776
    TopDawg1776 [OP] Well-Known Member
    Sam
    Nashville
    2022 Tundra TRD Pro
    I have been changing the oil in the Tacoma every 5K miles, I've been wondering when I should change the other fluids. Such as the coolant, brake fluid, front and rear differential fluid, power steering, and ATF.
    Does anyone recommend when I should do these as I intend to keep this truck for a long time.
    BrokenMech likes this.
  2. Apr 20, 2018 at 8:32 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    There is a small book in your glove box, check that.
    taco2010trd, stickyTaco and Bebop like this.
  3. Apr 20, 2018 at 9:19 AM
    BrokenMech
    BrokenMech Well-Known Member
    Upstate, NY
    2019 4Runner TRD Pro
    I use this site for reference:
    https://sites.google.com/site/tacomamaintenance/
    Hope that can answer some of your questions.
    ChadsPride likes this.
  4. Apr 20, 2018 at 9:45 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Front and rear diff and T-case every 30k
    Radiator every 100k
    Brakes every brake replacement
    Power steering you can do at 100k
    Transmission 100k (or 60k if you tow)
    Check your fluids regularly. Change them more often if they look bad.
    I don’t touch my brake or powersteering fluid until it looks like it needs to be changed. Exception is when I change the brakes or replace a powersteering pump.
    I would have the transmission flushed at 100k. Not a drain and refill but thats my personal preference.
  5. Apr 20, 2018 at 3:34 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Just me but here's what I do...
    Diff every 30k
    A/T every 30k
    Coolant every 100k or 8 years
    PS every 2 years using the turkey baster method
    Brake Fluid every 5 years
    I don't tow or drive in unusual conditions, none of these services are expensive and if it makes my truck last longer I'm happy. What's the old saying "grease is cheaper than steel"
    BassAckwards likes this.
