When do you have to regear?
Discussion in 'Wheels & Tires' started by wingshootin, Mar 7, 2010.
  1. Mar 7, 2010 at 6:03 PM
    wingshootin
    wingshootin [OP] Well-Known Member
    Jonathan
    Columbia, SC
    2006 Taco LB TRD Sport 4x4
    3" suspension lift Custom wheels Oversized M/T tires
    Question for you guys and gals. I know this has been answered before but here goes again. When do you have to regear or when is it suggested. For example:
    I have a 3" lift on my 06 TRD Sport LB DC 4x4 with after market wheels. The wheels are 17x8 with a zero offset and 4.5 back spacing. I have and I am still thinking about doing a 6" lift kit but I do not know if I can justify the cost or not. Anyway my question is this....with my current set up when do I need to worry about having to regear? Whats the max tire size that I can go with without having to worry about regearing? I am leaning towards the 295 70 17's. Any info would be greatly appreciated. Thanks
  2. Mar 7, 2010 at 6:08 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Depending on what you do with your truck. As in do you wheel it alot or just want it looking good for when your in town. If its just for town your 3.73's should be fine even with 35's. Unless you need the lower gears for crawling on the trails. Just my $.02
  3. Mar 7, 2010 at 6:27 PM
    wingshootin
    Jonathan
    Columbia, SC
    Its for both looks and fuctionality. I offroad every now and then. Mainly mud and red clay.
  4. Mar 7, 2010 at 6:31 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    general rule of thumb if you change your diameter by more then 10 percent then you should regear to get back inside the window. so i just used the tire size calculator, its a 5.2% difference so it wont be necessicary, but inorder to get the gas mileage and the power back you could regear to 4.27 but more likley 4.56 because it is hard to find the 4.27s for our truck
  5. Mar 7, 2010 at 6:40 PM
    wingshootin
    Jonathan
    Columbia, SC
    Just the answer I was looking for. Thanks man.
  6. Mar 7, 2010 at 6:47 PM
    ktmrider
    Junk
    no problem I like your DCLB too
  7. Mar 7, 2010 at 7:19 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Don't forget if you have an auto and you have 35's with 3.73 gears. Your transmission could easily become overheated which Heat=Flinstones. 33's are fine I just bought a bigger transmission cooler. 6" lift you should definitely re-gear to get you power and gas mileage back as well as saving your auto.
  8. Mar 7, 2010 at 7:22 PM
    ktmrider
    Junk
    Its not completely necessary to regear if you dont have to. It puts extra stress on your transmission but some people go from stock size to 35s and run it for years. Im assuming your truck is 2x4? if it is the regear should run about 400 bucks, and you can totally regear a 2.7 5 lugger. Email allpro offroad, they carry gears for our trucks and they can direct you through. Also a bunch of people on here have regeared, and you can ask them. try http://www.tacomaworld.com/forum/2nd-gen-tacomas/59900-more-gear-ratio-s-4-56-a.html
  9. Mar 7, 2010 at 7:40 PM
    RedTaco2134
    Scott
    Portland, Or
    Well I guess if the person never went off-road, I guess it would be fine. 35's with 3.73's and a stressed drivetrain, asking for problems..I could feel the power loss from the step up from 245/65/17-275/70/17(32"). My truck is very Lackluster compared to the 245's(30") Just my $.02
  10. Feb 22, 2011 at 3:15 PM
    RDAY
    RDAY Well-Known Member
    NY
    07 Tacoma SR5 4x4
    roughly wut does it cost to regear our trucks at a shop
