When/How to use 4x4?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wxm8562, Dec 9, 2016.
  1. Dec 9, 2016 at 11:07 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Well... in farm tractors the front axle actually spins faster than the rear axle to pull the rear through whatever. I've actually wondered if that was true in the automotive industry.
  2. Dec 9, 2016 at 11:09 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Since it hasn't really been mentioned. In my experience in snow, locked differentials are terrible. To clarify a tire may break traction while the others holds traction however a locked differential can cause both tires to break traction.
    EDIT: I guess it doesnt matter though since you have to be in 4Lo to use it on a Tacoma.
  3. Dec 9, 2016 at 11:14 AM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    It definitely depends on the snow depth and type, but I've used my locked rear in deep snow and it was an enormous traction aid. Turning sharp turns as you mentioned with a locked diff will cause the one wheel to brake lose.
    Most snow plow guys lock their rears as the added traction pushing in a straight line is significant. Also had a newer rubicon out in 18" of fresh snow off-road and using the front and rear diff locks were able to get unstuck several times.
    I think it is just down to application and driving style - you certainly have a point that they should be used sparingly. Toyota also says not to use 4LO and the rear diff lock above 15-20 MPH so its pretty restrictive for on-road use.
    JoeCOVA[QUOTED] likes this.
  4. Dec 9, 2016 at 11:16 AM
    Toyko Joe
  5. Dec 9, 2016 at 11:42 AM
    MO Tacoma
    MO Tacoma Well-Known Member
    Castle Rock, CO
    2014 DCLB with a couple mods
    ADS extended travel, 14" 700 lb springs, Total Chaos UCA/LCA, Dakars. 37/12.50r17 Pitbull Radial Rocker. SCS 17" SR8. 4.56s with f&r ARB lockers. Relentless sliders, full skids, debadged. 35% tint on all windows. Katzkin leather w/ heated seats
    Do your research.
  6. Dec 9, 2016 at 11:48 AM
    JoeCOVA
    Joe
    Colorado Springs
    I think its clear here that your comments raise more questions than mine and between the two of us I have provided more resources and information on the topic. I have decades of practical 4wd research..
  7. Dec 9, 2016 at 11:59 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    My truck will not even engage above 62. #angry beeping#
  8. Dec 9, 2016 at 12:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Just remember, 4WD doesn't mean shit when braking (unless you're engine braking). I see it all the time when someone is all "Herp derp I have 4WD so I'm invincible" and then they're the first ones to crash.
  9. Dec 9, 2016 at 12:14 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    At least they can herp derp out of the ditch they slide into
  10. Dec 9, 2016 at 12:17 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not if you're this guy.
    Kyitty, Spare Parts and TACOmobbin like this.
  11. Dec 9, 2016 at 12:17 PM
    wolmar72
    wolmar72 Well-Known Member
    Jon
    Newport Beach CA
    12 dual cab 4x4
    owners manual
    Toyko Joe likes this.
  12. Dec 9, 2016 at 12:36 PM
    TACOmobbin
    TACOmobbin Well-Known Member
    CO/CA/AZ
    CURRENT: '17 TRD OFFROAD PAST: '16 WRX STI; '12 TRD OFFROAD
    I'm sorry - how the hell would it make sense that your front wheels are turning faster than your rear wheels while driving? That is the dumbest thing I've read all day, and thus far I have already briefed two WC cases and have read through about 80 pages of a deposition. That definitely takes the cake.
    siznarf and maypearl like this.
  13. Dec 9, 2016 at 12:38 PM
    JoeCOVA
    Joe
    Colorado Springs
    They only turn faster in a turn and only slightly because your fronts are turning slightly wider than the rears
  14. Dec 9, 2016 at 12:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    We aren't going to tolerate people being dicks on here. If you even think you're gonna be a dick, be prepared to be banned.
    Vanderjdm, Jleeb, Kyitty and 3 others like this.
  15. Dec 9, 2016 at 12:39 PM
    #35
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That was pretty damn swift. I was wondering if he deleted it himself or if a mod did.
    chris4x4[QUOTED] likes this.
  16. Dec 9, 2016 at 12:40 PM
    #36
    MO Tacoma
    Castle Rock, CO
    Thank you for explaining it better than I did. There is definitely holes in my explanation. Sorry for that. Mud, sand, dirt or whatever low traction
    Thank you for explaining it better than I did. I should have put a lot more details. My explanation was full of holes:smack: The inside front tire will want to turn slower but when in 4wd it turns faster (same as the rear) it will prevent the fronts front digging in to whatever low traction situation. Mud, dirt, sand whatever off road. That's why some mud bog guys run different gears in the front to help prevent the front from sinking in.
  17. Dec 9, 2016 at 12:58 PM
    #37
    Summitroad
    Summitroad Well-Known Member
    Northen CA
    TRD OR 4X4
    I think we went off topic a bit, the OP question was ....
    "When should I be using 4 hi? I'm interested in how to properly use it in snow. Is it safe to just turn it on while driving down the road? Should the road be snow packed first? Just some snow/ice? Should it only be used to get moving if I'm stuck? Used on the express way?"
    I am also interested to learn the proper and safest way to travel snowed, icy, and muddy roads. So my question is, why is not recommended to use the auto LSD at all times in this kind of roads?
  18. Dec 9, 2016 at 12:58 PM
    #38
    maypearl
    maypearl Well-Known Member
    Joe
    Maypearl, TX
    17 Taco DCSB 4X4, 16 Canyon Diesel 4X4 SLT
    Look out it's the COPS!
    I kid, I kid. Please don't ban me sir. I was just walking home and happened upon this party. :bowdown:
  19. Dec 9, 2016 at 1:05 PM
    #39
    su.b.rat
    su.b.rat broken truck
    David K or somebody correct me if I'm wrong here, but I believe this is because auto LSD requires VSC to be off, and that's the main reason. VSC offers both braking and throttle control where auto LSD only offers rear braking with no throttle control, which on roads may often be less safe.
  20. Dec 9, 2016 at 1:06 PM
    #40
    JoeCOVA
    Joe
    Colorado Springs
    https://www.tacomaworld.com/threads/a-trac-trac-auto-lsd-explained-easy-to-understand-i-hope.70551/
