When is enough maintenance to warrant keeping your Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, May 28, 2019.
  1. May 28, 2019 at 6:48 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i cannot read @vettehigh mind :D ... the ? seems open ended ?
  2. May 28, 2019 at 6:51 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    If you don’t like paying to maintain a vehicle... don’t own a vehicle.
  3. May 28, 2019 at 6:58 AM
    Glamisman
    Glamisman Well-Known Member
    if you can do the majority of the work yourself keep her forever. Like mentioned above, to replace her will be minimum new $35k and I am not sure that you would want it. The amount of electronic sub systems adds to the complexity and extreme costs when out of warranty. Tire air pressure sensors, slip angle sensors, ABS pumps etc.
    When she needs a transmission is usually when I make the decision. Even with a competant shop doing the work an automatic never seems to be the same.
    cruiserguy likes this.
  4. May 28, 2019 at 8:05 AM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    I had the clutch go out on my truck in late 2018 so I had my mechanic replace the clutch & carrier bearing, and serviced both differentials since it hasn't been serviced for close to 20 years since I've owned the truck. :eek: Then my truck engine blew a head gasket in December and was able to drive the truck to the repair shop with the engine on its legs (water/coolant leaking from underneath, Yikes!) after 20 years and 275K miles. Taking the advice of my mechanic, I had him do an engine swap with another 3.4L motor with 130K on it, install a new radiator/water pump/hoses/timing belt/mass air flow sensor. After the engine swap, I had to have the truck smog to renew my registration. I passed and got my registration squared away with.
    Since I didn't perform the engine swap & related work, it costed me about $6K for the engine swap & labor, but my truck mechanically under the hood has a mid life refresh to last me another 10 to 15 years. To the OP, your parts list is typical for an engine rebuild, but comes with the territory if you intend to keep your truck. You'll find a lot of satisfaction when the work is done properly and knowing that your engine will last you for 200K + miles.
    onakat and GQ7227[QUOTED] like this.
  5. May 28, 2019 at 8:08 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    :eek:
  6. May 28, 2019 at 8:37 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    95% normal stuff to be replacing on older vehicles. plugs, headlights, oil, filters, timing belt , water pump, etc... Not sure why you got a custom painted oil pan, though... :confused:
    Bed liner is not a maintenance item. Kind of unfair to include that, that has nothing to do with the longevity of the vehicle.
    But if you are itemizing each and every bolt you're buying, it's time to hang it up and lease your next vehicle...
  7. May 28, 2019 at 8:40 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    The oil pan had to be painted, it comes from the factory all scratched and not painted. I was not charged for the paint job on the pan though
    GQ7227 likes this.
  8. May 28, 2019 at 8:42 AM
    jbrandt
    Justin
    why did you replace it in the first place, though?
    Also, you seem to be getting a LOT of OEM parts, and I assume aying through the nose to do so. There are a lot of things where that just doesn't make sense and is unnecessary.
  9. May 28, 2019 at 8:45 AM
    vettehigh
    Jon
    Upstate, NY
    Like I said in my earlier post, I get all OEM parts at dealer cost and sometimes 10% below that. As for the pan, it was very rusty in the front
    DavesTaco68 and GQ7227 like this.
  10. May 28, 2019 at 8:51 AM
    95tojo
    95tojo Well-Known Member
    Jared
    So IL
    '19 Cement Grey TRD Sport 4x4 6MT
    I'm honestly shocked that a 95.5 is still alive in upstate NY. Figured all of them were piles of rust by now. :thumbsup:
    GQ7227 and vettehigh[OP] like this.
  11. May 28, 2019 at 8:59 AM
    jbrandt
    Justin
    I missed that post, sorry.
    So you're into this thing for $12k. So do you still think it's worth it? I'm guessing that because you've started itemizing every last item (down to the bolts) you've repaired/replaced, you're tending towards it not being worth it.
    It definitely sucks to have to do all that stuff in the same year, but when you own a vehicle for a long time, you are easily able to spread that cost out over a lifetime of ownership. I've owned my truck 15 years. The biggest 1 time expense I've ever made on it (besides my Kings and UCA's, or tires, lol) is the timing belt kit. Every thing else has been $100 here, $50 there...
    You have a few alternatives if this is too much for you:
    1) Buy a new truck at $35k min.
    2) Lease a vehicle for $200-$400 a month.
    3) Buy a bicycle.
    12TRDTacoma, CS_AR and Luv my yota like this.
  12. May 28, 2019 at 9:01 AM
    vettehigh
    Jon
    Upstate, NY
    After all I did and will be doing next week, it's forever staying with me :fingerscrossed:
  13. May 28, 2019 at 9:07 AM
    jbrandt
    Justin
    yeah, you should be good for another 200k, lol
  14. May 28, 2019 at 9:29 AM
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    That's a pretty decent list, you might have to do U-Joint or CVs sometime too, they can wear out. I had to get a new O2 sensor with similar miles to yours. But it should run for a very long time trouble free like everyone else is sayin..
    Hamer95USA, CS_AR and GQ7227 like this.
  15. May 28, 2019 at 9:32 AM
    #35
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    This. I've never heard of a shop that can correctly and 100% rebuild Japanese auto transmissions. I'm sure they exist but man a high quality auto rebuilder could make a killing if he wanted to. It almost tempts me to do myself with FSM if time ever comes, eventually time should come I'd think
    CS_AR likes this.
  16. May 28, 2019 at 9:37 AM
    #36
    GQ7227
    GQ7227 mw survivor
    J A Y
    i beg to differ! winter climate will rot beds out BAD i have seen proof
    Breakfast Taco likes this.
  17. May 28, 2019 at 9:41 AM
    #37
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Yup U-Joints and carrier bearing are the only things I saw missing that go out by then usually.
    GQ7227 likes this.
  18. May 28, 2019 at 10:25 AM
    #38
    jbrandt
    Justin
    Not where I live, lol...
    I generally adhere to what the manufacturer recommends as "regular maintenance" items (changing filters, oil, gaskets, etc...) as detailed in the service manual. Anything else is regional or personal preference type stuff.
    Polishing and waxing it, and vacuuming the interior is a good way to keep it looking nice for longer, too, but IMO isn't really "maintenance"...
    Hamer95USA and GQ7227[QUOTED] like this.
  19. May 28, 2019 at 10:25 AM
    #39
    vettehigh
    Jon
    Upstate, NY
    I would need 2 U-joints right (same part number front/rear) and 1 carrier?
    U-joints: 04371-60070
    Carrier: 37230-35130
  20. May 28, 2019 at 10:28 AM
    #40
    GQ7227
    GQ7227 mw survivor
    J A Y
    would a complete and total frame rehab warrant me keeping my taco :confused:
    its not a laughing matter hahah, it is as real as you can imagine
    i can see your point, though
    but to prevent major body damage in probably 1/3rd of the country this (bed liner) must be done (if using as 'normal' truck stuff, carrying objects in the bed and scratching it up)
    the other gens have fiberglass composite? bed so they don't need to worry as much
    Luv my yota likes this.
