When is enough maintenance to warrant keeping your Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, May 28, 2019.
  1. Jun 4, 2019 at 10:48 AM
    #81
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Woah. Wait a minute. People do it all the time without removing the AC bracket. It just takes a wobble joint and some concentration.
  2. Jun 4, 2019 at 10:55 AM
    #82
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    I will tell that to him
    GQ7227 and CS_AR[QUOTED] like this.
  3. Jun 4, 2019 at 11:04 AM
    #83
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    All the OEM parts, the painstaking care in tracking it, this was a labor of love dude. And yeah, as someone said before it's too late to make that call. Just enjoy the truck and all its fresh parts for as many miles as you can.
  4. Jun 4, 2019 at 12:12 PM
    #84
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    OP, honestly, if i had it to do over and could've found one for a reasonable price that wasn't beat on by a 16 yr old for $4500 or owned by the same family since new for $12.5 i would've bought a used older one and done all the same and probably more just like you..i say enjoy it man, it'll bring you more happiness knowing what is fixed, and what you would like to be done versus going on a date and have something go wrong and then have to play catch up on all of it which would then seem never ending.. having an '18 is cool and all but in reality what does mine do that yours couldn't? don't get me wrong i love my truck and (to me) its worth every penny everyone around my area thinks they have a lump of gold hidden somewhere in their POS or they have the next Barrett-Jackson record holder only because they've had it in the same family for 25 yrs doesn't mean it runs and drive worth a shit..don't worry about the dollars and cents man, its all relative in the big picture...enjoy the truck and post up some pics
  5. Jun 4, 2019 at 2:32 PM
    #85
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    All the dollars. Any amount of maintenance still beats a $500 a month car payment. I'm sure someone else already said this.
    Santos23, indowaver, Kiloyard and 4 others like this.
  6. Jun 19, 2019 at 6:21 AM
    #86
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    Proof. Just changed my bed:
    GQ7227[QUOTED] and 2002Tacoma4x4 like this.
  7. Jun 19, 2019 at 6:59 AM
    #87
    GQ7227
    GQ7227 mw survivor
    J A Y
    @vettehigh what are your thoughts, how do you feel about seat maintenance
    this is the issue (one of a few) I am now currently facing and dealing with, already put some good cash into it a couple weeks ago attempting to fix inner problem(s),
    and its not TOTALLY fixed for me to feel safe to drive it anymore
    maybe this warrants me not to keep it, i dunno
  8. Jun 19, 2019 at 8:46 AM
    #88
    vettehigh
    Jon
    Upstate, NY
    What do you mean by "seat maintenance" Older I get, more I forget
    GQ7227[QUOTED] likes this.
  9. Jun 19, 2019 at 8:50 AM
    #89
    GQ7227
    GQ7227 mw survivor
    J A Y
    say if your seat becomes a 'chore' and just get so fed up with it, what to do?
    I think you have AT? so you might not have similar situation as I have going on currently with MT
  10. Jun 19, 2019 at 1:55 PM
    #90
    vettehigh
    Jon
    Upstate, NY
    AT I have
  11. Jun 20, 2019 at 4:09 AM
    #91
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    It’s a good question OP and good opinions out there, the way I see things is how much cost to keep it for month while you own it, obviously the best car or truck is the one that is paid off, but for sure maintenance is require for everything... I feel like sharing my list of $25,000 investment on this truck; if I keep it 10 yrs then at this point I'm looking at 208 monthly / 7 dollars a day ... anyway ... It's just a thing that I like to see co$t, but like someone already said it... "I have to stop counting...:rolleyes:
    1 owner corporation, Clean Carfax 55K miles 2016 now 82,300 miles.
    New Battery. New belts
    4Runner wheels with 245/75/R16
    Keller Safari off road E load GoodYear tires
    2 recalls done at Toyota of Plano:
    2 LBJ's replaced and
    Spare tire holder bolts and rust inspected
    A\C was served, new 2 me :rolleyes: on 08-08-2016
    Then we started replacing and maintaining: :spending:
    1. Replace the damaged Chrome plate Rear Bumper OEM
    2. Repair driver side tail corner metal & install body filler driver's headlight
    3. DYI clean\convert\Paint Frame Surface Rust w\ Eastwood & ChassisSaver.
    4. Replace wheel bearing left rear with lock shim kit 1 wiring retainer and 1 new drum hardware kit , replace brake shoes rear includes clean, lube and\or replace hardware as necessary. Axle shaft seal remove and replace Driver rear side.
    5. Replace worn out broken weather strip driver side.
    6. Clean MAF , fuel injection cleaning, flushed all OEM fluids and replaced them with new BG full synthetic additives
    7. New battery 2019
    8. Remove and replace axle and seals, all OEM at Toyota Dealer, had to disassemble axle that was on vehicle to remove backing plate and transfer to the new axle assembly, then clean prep and install new rear brake shoes, adjust and install drums, then bleed the brakes , fill rear end, test emergency brake operation, then test drive is good.
    Shoe kit , Brake,RR
    90W Gear Oil
    Seal type K oil
    Case, RR axle bearing
    Ring, O
    Bearing , radial ball
    Ring, Shaft Snap
    Seal, Type S oil
    Rotor, Skid control
    Retainer, RR axle bearing
    Ring, Shaft snap
    Shaft, RR axle
    Nut, Hub w\washer
    Six new studs
    9. Replace front struts, rear shocks, both lower control arms and bushings; replace steering rack and sway bar bushings, wheel alignment, all OEM exceptfor shocks Gas-A- Just KYB.
    COMFORT AND UPGRADES :spending:
    1. Ceramic Window tint driver and passenger front doors and the windshield.
    2. LINE-X bedliner over rail.
    3. Security system upgrade with 2 way remote control starter.
    4. 4Runner wheel caps, bedplug \key Gas cap\ wipers & AVS bug deflector
    5. New OEM Tacoma Floor Mats.
    6. Install new OEM towing hitch and wires.
    7. OEM running boards.
  12. Jun 20, 2019 at 6:35 AM
    #92
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It's never enough so long as you plan to keep it. Don't tally up what you spend cause you aren't going to get that money back.
  13. Jun 20, 2019 at 6:57 AM
    #93
    GQ7227
    GQ7227 mw survivor
    J A Y
    what do you suggest doing when a replacement part is needed that is (sorry) no longer available
  14. Jun 20, 2019 at 6:58 AM
    #94
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Live with out, modify a similar part or make your own.
  15. Jun 20, 2019 at 6:58 AM
    #95
    vettehigh
    Jon
    Upstate, NY
    Get the closest thing to it...never had that issue. Think I might have with an interior part
    2002Tacoma4x4 and GQ7227[QUOTED] like this.
  16. Jun 21, 2019 at 9:32 AM
    #96
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    OP, you have way too much invested in it now to give up. Like others have said you have what amounts to a nearly new truck you should enjoy it. You’re still about 1/3 of what a new replacement would run you. And what’s he alternative? Park it? Then you just wasted a boatload of money. Sell it? Not likely recoup what you’ve spent. Drive it. Enjoy it.
  17. Jun 21, 2019 at 9:41 AM
    #97
    1997tacomav6
    Denver
    Yup just drive it and take care of it.
  18. Jun 21, 2019 at 10:00 AM
    #98
    GQ7227
    GQ7227 mw survivor
    J A Y
    this is gonna be one heckuva tall task with my interior :mad:
    Luv my yota likes this.
  19. Jun 21, 2019 at 2:49 PM
    #99
    Kevins60
    Kevin
    Odessa FL
    Just did some quick figuring on the odo on John’s post. 595,000 miles. Rough equivalent of driving around the world 5 times and then driving to the moon and back. Wow. NASA should start launching Tacomas
  20. Jun 21, 2019 at 2:55 PM
    #100
    GQ7227
    GQ7227 mw survivor
    J A Y
    @1997tacomav6
    has your truck ever left Colorado?
    where all has it been?
