When is it really necessary to replace rotors and calipers when doing brakes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoastieTX, Jun 10, 2021.
  1. Jun 10, 2021 at 8:42 PM
    CoastieTX
    CoastieTX [OP] Well-Known Member
    PNW
    Original owner 1998 Tacoma TRD; 3.4 V6 with 5 MT
    The rotors currently on my truck have never been turned and don’t pulsate when braking. Calipers are originals and are working just fine.
    Seems there’s lots of different ways garages replace brakes. Some will replace the pads and resurface/turn the rotors. Others want to replace the rotors with the pads. One recommended replacing the calipers, too.
    Since these parts are easily accessible, what’s the harm in just replacing the pads and and having the rotors resurfaced? How likely are the rotors to warp after being resurfaced once?
    Am I right to be skeptical that automatically replacing the rotors, and especially the calipers, is just a cash grab?
  2. Jun 10, 2021 at 10:12 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    As long as you dont have any vibrations, and are keeping an eye on things - making sure pads are wearing evenly, alert to pulling one way or the other when braking, the smell of brakes smoking when you haven't really been on them (i.e. the things that would indicate a stuck caliper), then there's no real reason to replace anything proactively.
    The possible exception to that in my book would be the rubber brake lines (from the frame to the calipers). Rubber wears out over time, and you'd get better performance from a set of stainless steel lines anyway, so that might be something to consider.
  3. Jun 10, 2021 at 10:17 PM
    Bishop84
    Bishop84 Well-Known Member
    1st gens were known for pulsating brakes usually due to overheating or excessive runout from pad material. So many techs gave up on resurfacing them. 4runners are really bad.
    I machine rotors dependent on condition. But I use an on car lathe. They are more true to the rotor and are the only effective way to machine truck rotors.
    https://www.youtube.com/watch?v=IUr9b8AA_g8
  4. Jun 10, 2021 at 10:38 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I only replace rotors when it's starts pulsating on braking or if the thickness goes under spec. Rotors are super cheap anyways. I think I bought a new set of Raybestos rotors from rockauto for like 30 bucks. I think it costs that much if not more to resurface them. The pulsating immediately went away after replacing them.
  5. Jun 10, 2021 at 10:48 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Buy some rotors from autozone. Can exchange them as many times as you want for 3 years
  6. Jun 10, 2021 at 11:34 PM
    mk5
    mk5 Probably wrong about this
    SoCal
    '05 access cab 4x4
    Personally, I run a coarse roloc pad over my rotors each time I remove them... just enough to skim away the glaze and rust, plus just a bit more out of spite, but never more than that. Consistent pressure is key. Then I'll buzz the glaze off the pads too. Always easiest to bed fresh friction surfaces.
    I re-bed the pads by driving like a total ass hole for a few days. Works every time.
    I used to replace pads and rotors annually because of the slightest pedal vibrations -- what a waste of money! Now I know: although uneven rotor/pad wear might eventually cause pedal vibrations, as might perhaps also the flutter of distant butterfly wings, so long as you can half-heartedly take a refinishing disc to your rotors and pads twice a year, then drive recklessly while blaming your faults on others for a few days, then your brakes are fine and you should buy a jet ski.
    Kevins60 and Taco! like this.
  7. Jun 11, 2021 at 5:22 AM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    It's necessary when you first buy a Tacoma to upgrade to Tundra 13WL brakes :)
    1blink likes this.
  8. Jun 11, 2021 at 10:49 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    When I used to live in the mountains I need to replace my brakes (and tires) much more frequently than I do now. However, I still follow the same pattern: I have two sets of rotors- one active set on the truck, and the next set waiting to go on. I turn the inactive set between pad changes. I can usually get three turns out of each rotor before they are out of spec, and can't be turned again.
    You only should replace the calipers if you suspect they have an issue (sticky or leaky piston). They can also be rebuilt, which I wish I would have done, rather than replacing mine when I did. The remanufactured replacements rusted very quickly, and I had to pull them off again, wire wheel them clean, and paint them.
    What that all boils down to: don't replace stuff just cause. Have a good reason to do replace things, especially with non-oem parts.
  9. Jun 11, 2021 at 7:11 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Make sure to clean the rust corrosion where the rotor will sit on the hub. A wire wheel is good for this. A minute amount of rust can cause the the rotor to be untrue when mounted
  10. Jun 11, 2021 at 7:13 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Rebuild the calipers if unsure. Super easy!!
  11. Jul 3, 2023 at 8:02 PM
    PinktacoDM84
    PinktacoDM84 Well-Known Member
    Dan
    BC
    2015 trd OR/AC
    St Maxx on Trd pro wheels, mbrp exhaust, k&n cai, jba's, 887's over 5100's, medium dakars and 5125's.
    My families go to mechanic told me that with tacomas, one of the four pistons on each caliper almost always seizes around the 100k kilometre (60k+ miles) mark. My pads are at 15% now, I just rolled over 60k miles, and he said I can put new pads on, but that most likely within the year the Calipers will seize and the pads will be wasted, if they aren’t seized already when attempting to replace the pads. This guy has been really honest with my parents over the years, persuading them not to do things that Toyota has recommended ‘just cause’, and in turn, saving them money.
    Is he full or shit here?
  12. Jul 3, 2023 at 8:14 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Depends where you live I suppose. My old calipers had 170k before I did the Tundra upgrade and they worked perfectly fine.
  13. Jul 3, 2023 at 8:17 PM
    PinktacoDM84
    Dan
    BC
    2015 trd OR/AC
    Are we talking 170k Miles? I literally live beside the ocean so I'm guessing the salinity takes it toll.
  14. Jul 3, 2023 at 9:28 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Yeah 170,000 miles. Salt definitely lowers the life expectancy of many things.
  15. Jul 4, 2023 at 9:02 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    To me there are no hard rules everyone uses and drives there vehicles different.
    When I buy a new to me vehicle I change to all new Front Brake hardware. When doing the neglected maintenance catch up.
    After that to a as needed change.
    Anymore all the local shops say turning Rotors is more expensive then replacing.
    Area51Runner likes this.
  16. Jul 6, 2023 at 9:18 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    yes, but also make sure rear shoes are correctly adjusted
    Bivouac likes this.
  17. Jul 6, 2023 at 10:42 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Flush the brake fluid out and replace, shouldn't stick if it's clean inside the caliper.
  18. Jul 6, 2023 at 10:56 AM
    Bivouac
    Here is one of the problems the longer the brake fluid is in the system the more water collects.
    From the normal thermal cycling . Some owners might go 5 or10 years without a major fluid change.
    To the point the hydraulic moving parts start to develop pits to the point they can no longer be rebuilt without machining which is not effective .
    Till your dealing with expensive hydraulic cylinders.
