When should I change my diff oil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by soggyBottom, Jul 3, 2021.
  1. Jul 3, 2021 at 11:32 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    I've never had issues with hex (allen) heads. On my past rigs I've changed everything to allens. I will do the same on this 2020.
    Superdave1.0 likes this.
  2. Jul 3, 2021 at 11:49 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Depends on where u live I think. The rust belt is brutal.
    Doghouse61, shakerhood and CrufflerJJ like this.
  3. Jul 3, 2021 at 7:31 PM
    jsi
    jsi Well-Known Member
    native earthling
  4. Jul 3, 2021 at 7:39 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Right on.
    jsi[QUOTED] and Tacospike like this.
  5. Jul 3, 2021 at 7:45 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I smashed my thumb under the breaker bar when that damn plug broke free, goes from a ton of torque to zero torque in a fraction of a turn.
    Junkhead[QUOTED] and CrufflerJJ like this.
  6. Jul 4, 2021 at 5:23 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Helps if you have 1/2'' quality allen wrench socket bits with a good drive ratchet to get the proper bite on those plugs.
  7. Jul 4, 2021 at 5:32 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Front or rear diff?
    I just did the fluid change on the front, and there could not be two plugs with less room to maneuver a breaker bar on the whole truck. Perfect setup for smashed knuckles, too.
    Soaked mine in PB Blaster hours before I tried to remove.
  8. Jul 4, 2021 at 5:34 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Exactly, I thought for sure I’d broken something (the hex bit? The plug? My hand?) when the plug finally moved. It was sudden and violent.
    jsi and shakerhood[QUOTED] like this.
  9. Jul 4, 2021 at 5:38 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    79CHKCHK and daveeasa like this.
  10. Jul 4, 2021 at 7:27 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Rear was fine, breaker bar and some dings to my thumb and it was loose.
    Front is the hard one it seems. I read about using a hammer but didn’t understand that the hammer goes to the plug and diff to break tension. And I honestly don’t feel comfortable whacking a vehicle with a hammer.
    I munged the Allen a bit from torquing it on some ramps. It’s now into the danger zone where another tug might round it entirely.
    The funny part to me is that I’ve wasted 2 full days getting no help on this from my local shop. TW was/is far more useful. They didn’t even have a pump and whined about the time to remove the front skid which I had off before I dropped it, as if this request was just too difficult for them, despite having 5 or 6 lifts.
    I’m not sure if I can trust the dealer any more but at least they can order parts if they destroy something else.
  11. Jul 4, 2021 at 7:51 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    I did my front/rear and Xfer case all at 60k. Rear was a bit darker, everything else looked new. The bolts put up a little fight, but Im in the rust belt. That may be a good reason to do it earlier if you care.
  12. Jul 4, 2021 at 8:20 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    The only way my front came loose was by cutting into the plug. Basically cut a straight groove and chiseled the mangled bastard off. NICE to have a REAL fill plug.
    daveeasa likes this.
  13. Jul 4, 2021 at 5:33 PM
    jsi
    native earthling
    The first time I did mine the front drain plug was a PITA. And, the second time I did mine the front drain plug was a PITA. Like others have said it sounds like you have broken something when I finally lets loose. Make sure your fingers are out of harms way or it will hurt like a son of a bitch. IMO a breaker bar and a 1/2" allen socket are a requirement for the task.
  14. Jul 4, 2021 at 7:34 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    The next time I do the front diff I’m hitting the breaker bar with a rubber mallet.
    jsi[QUOTED] and shakerhood like this.
  15. Jul 4, 2021 at 7:41 PM
    #35
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Man I love living in AZ.
    shakerhood likes this.
  16. Jul 4, 2021 at 8:21 PM
    #36
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    The underside of my truck is still pretty pristine living here in NC. It’s the hex plugs...if they were 24mm like the rear diff, they’d be easy.
  17. Jul 4, 2021 at 8:27 PM
    #37
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    daveeasa and jss1975snow like this.
  18. Jul 4, 2021 at 8:55 PM
    #38
    jsi
    native earthling
    Folks be heaping hate on the allen drain plug, but all I have is a set of $8.00 harbor freight allen sockets like this[​IMG]
    It's plenty salty around here, but with a breaker bar the drain plug came out without too much of a fight. Well, lean on the breaker bar, see it flex, almost sure something is going to break, lean a little harder, think I should give up, CRACK! Count the fingers, still got ten, check diff case for damage, none, what broke? Oh, the plug is loose!
    evotacoma and Hook78 like this.
  19. Jul 4, 2021 at 9:25 PM
    #39
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Stock gears I did 30k changes but with 5.29s and 35s East coast gear supply recommends 15k changes. I wheel a ton so it's needed
  20. Jul 4, 2021 at 9:53 PM
    #40
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    I’m gonna do mine at 100k. Just oil and filters (oil, intake, cabin) until then. Fluid swap front to back at 100k and plugs. Just me. I’ve done the same schedule on all my cars and never had an issue. I’ve had anything from outback’s to M3’s to cobras. Just always been my go to
