When should I change tranny Fluid ?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Uncelou1980, Jan 13, 2011.
  1. Jan 13, 2011 at 3:07 PM
    Uncelou1980
    Uncelou1980 [OP] Active Member
    New Jersey
    2006 Toyota Tacoma Pre-runner 2WD Double Cab
    Hello friends from Tacoma World !!!!
    I have a 2006 Toyota Tacoma Pre-runner 2WD ( i bought it brand new) and it only has 42560 miles( not bad for a 2006 ) ,,,, Does anybody know the what's right milage to change the tranny fluid ???? I only drive in the city ( New Jersey and New York City ) from my house to work and from work back to my house and I go out on weekend but i never gonna off-road with this truck ....
    Thanks for the help ....
  2. Jan 13, 2011 at 3:19 PM
    mustangwilly
    mustangwilly Well-Known Member
    IL
    2017 DCSB OR Quicksand MT
    I've seen 60,000 miles throw around quite a bit.
  3. Jan 13, 2011 at 3:25 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I believe for the automatics it's 60,000 if you do any towing and 100,000 if not. I personally wouldn't wait till 100,000...just my opinion.
  4. Jan 13, 2011 at 5:10 PM
    Uncelou1980
    New Jersey
    Thanks for your help ....
  5. Jan 14, 2011 at 2:31 AM
    Potomac30
    Potomac30 Member
    SC
    2011 PreRunner
    If you're considering it, why not do it now? Changing tranny fluid is one of those things that you can't do too early, but you can do too late. Besides, city driving is harder on a tranny than highway.
  6. Jan 14, 2011 at 2:36 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    From some of the posts I've seen around here....it seems for newbs, it's when they do their first oil change......zing!!!
    Toyota recommends 100K miles for normal driving.
  7. Jan 14, 2011 at 2:39 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    ^^^^^^ that was cold ... funny but cold :D
  8. Jan 14, 2011 at 2:58 AM
    Sullyman
    Sullyman Crusty ole' conservative fart
    Augusta, Georgia area
    2010 Black TRD Sport
    Cat-back exhaust, BluLogic, Back-up Camera, Extang Solid Fold Tonnau cover, Pop-n-Lock PL8521 electronic tailgate lock, Illuminated 4x4 switch, Smittybuilt Nerf Step Bars, Toyota bed mat, Tinted the windows darker, CB with custom fab'd antenna mount, Grillcraft grill, AFE Pro Dry S filter with secondary filter removed. Differential breather relocation mod. Bridgestone Dueler AT/Revo 2 tires Weathertech mats Spec-D HID Halo's Bilstein 5100s front set at 2.5" w/OEM springs 4-leaf TSB w/ SkyJacker add-a-leaf
    Let your tranny change his/her own fluid...
    ...but seriously...consider using Slick-50 additive when you do it...I had a 5-6 year old auto-tranny Camry that I did that in....it was amazing the difference it made...you don't realize - during the course of day to day driving - how much things loosen up...That Slick-50 additive made it feel like a new car again...
  9. Jan 14, 2011 at 5:31 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    What does your owners manual say?
    I know my 2.7 has a 100,000 mile change interval but I thought the 4.0 had a 30,000 mile change interval.
    Whatever it is I would not exceed it.
  10. Jan 15, 2011 at 5:02 AM
    steviestyles
    Colorado Springs
    Bone Stock
    100,000K for the 4.0 as well; you might be thinking of the rear diff fluid for the TRD Sport??
  11. Jan 15, 2011 at 5:44 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    My dealership said that its a sealed unit, never needs changing. So Id say yea....your good at 60k. :D
  12. Jan 15, 2011 at 5:51 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    The dealer says 100K miles. When you look at the cost of fluid vs a replacement automatic transmission I'll continue to change it every 30K miles thank you very much.
  13. Jan 15, 2011 at 6:48 AM
    steviestyles
    Colorado Springs
    Bone Stock
    Overkill and a complete waste of time unless you tow, or off road the crap out of your truck. But hey whatever floats your boat. The Tranny is covered under the 60K mi Powertrain warranty. If Toyota specifies a 100K mi interval 99% of Tacoma owners will be fine going that long. Changing the Tranny Fluid isn't for the average internet mechanic and if done wrong can do more harm than good. Add in $10 for a quart of the Toyota WS fluid and our trucks use 4-5 quarts; every 30K miles isn't cheap.
  14. Jan 15, 2011 at 7:37 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    With Toyota saying 100Kmile service for auto's I'd say anytime you want unless you tow or haul heavy loads a lot.
    I'm a big proponent of draining the auto tranny pan every so often with the oil change and topping it back up with the same amount that came out. That only gets about 3 qts of the 11 qts total but it keeps the fluid fresh.
  15. Jan 15, 2011 at 7:40 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    $10 now? I thought it was about $8 or so. A complete drain and fill takes 11 qts...the pan only is in the 3-5 qt range so if he's doing it every 30k it's about right for doing the pan only.
