When spacer lifts go wrong
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Garrett75x, Jul 2, 2017.
  1. Jul 2, 2017 at 3:42 PM
    grichg
    grichg Well-Known Member
    rich
    Laguna Beach
    11 Tacoma 4x4
    Camburg 3.0 Coilovers Camburg A-arms All Pro rear bumper CBI Front Bumper LED Light Bar and PODs and some other misc
    I had those on a couple trucks in the past and NEVER had anything like this happen. And I drove them harder than I do my current real set up LOL
    nailersniper likes this.
  2. Jul 2, 2017 at 3:43 PM
    Bishop84
    Bishop84 Well-Known Member
    The strut compressed beyond its limit due to the spacer extending travel but no bump stop modification was made. So it bent the weakest link.
    MilkTeacoma, EDDO and c4lvinnn like this.
  3. Jul 2, 2017 at 3:44 PM
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    I already did and so did others in general terms. Shock ran out of shock travel and the force bent and broke said shock.
    Spacer lifts cause you to run out of shock travel upon compression of the shocks because you have a larger up travel (articulation) with the spacer. If the force is great enough, your internal bumpstops cant handle the load so it dissapates and breaks/bend the shock. Hence why someone metioned you should have a larger bump stop to limit compression/up travel.
    Or just do it right if you wheel, if not you should probably not jump curbs at 50mph at the mall with a spacer lift.
  4. Jul 2, 2017 at 3:55 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Yeah, I'm not blaming the spacer(s) plenty out there with no issues and it is reasonable alternative for sagging springs imo. But for lifting I'd spend $$ for the proper components to achieve the desired lift.
    bullaculla[QUOTED] likes this.
  5. Jul 2, 2017 at 4:56 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Yeah, sorry. I deleted my post because I re-read your post and you specifically were talking about the tension in the springs, not the nitrogen pressure. And yeah, I'd be really cautious removing that coilover. Scary stuff.
    The hammer[QUOTED] likes this.
  6. Jul 2, 2017 at 4:59 PM
    Broheim
    Broheim Well-Known Member
    San Antonio, TX
    2023 TRD Pro
    Toyota gives you warranty on their spacer lifts from the dealer.
    Spacer lift doesn't mean you can go jump dunes now. Just don't be an idiot and your suspension will be fine. I'm fine with spacer lifts if you know what your buying.
  7. Jul 2, 2017 at 5:12 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    This topic is beat to death, but the "best" suspension lift is based on its intended use. A daily driver, for example, wouldn't need a mid travel setup for everyday roads. Now, that's not to say a spacer lift is the best option, but for the price it's hard to beat. Lets admit it, not everyone researches and makes the best purchases. A majority of trucks I see on the road are on spacers/blocks. Most people don't have any problem with them unless they're taken off-road or under severe strain. Blocks are still used on many full size trucks to this day. As long as the user understands the limitations of the blocks/spacers, everything will be just fine.
    blackrifle76, Andrew H and bullaculla like this.
  8. Jul 2, 2017 at 5:13 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    This is the problem!
  9. Jul 2, 2017 at 5:26 PM
    Broheim
    San Antonio, TX
    2023 TRD Pro
    Youre hardcore.
  10. Jul 2, 2017 at 5:34 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    Thanks bro
    Midnighttaco08 likes this.
  11. Jul 2, 2017 at 5:37 PM
    cchicoine
    cchicoine Well-Known Member
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    GFC V2 Pro, OME Nitrochargers and heavy springs, Dakar heavy leaf pack, ECGS Bushing, Firestone airbags, MBRP cat-back Exhaust, FabFours Premium front bumper, Winch, Cali Raised LED ditch pods, CB radio, Motegi MR150 bronze wheels 16x8 0" offset, Falken WildPeak A/T4W 285/75 R16, Relentless Fab Tailgate reinforcement, painted headlights, AVS wind deflectors.
    First of all, im not getting spacers, but I am trying to learn as much as I can... So are you saying that if you do run a spacer kit and DO get new bumps like the super bumps or similar, you would avoid this issue from happening? thanks for dealing with my ignorance.
  12. Jul 2, 2017 at 5:38 PM
    c4lvinnn
    Front bump stops. Get bigger ones to avoid bottoming out the shocks if you go off road. I don't know exactly what brands there are for front bump stops though.
    hookembevo likes this.
  13. Jul 2, 2017 at 5:41 PM
    cchicoine
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    Makes sense, so the spacers reduce the up travel, which, with stock bumps, would overload the shocks and create a lot of pressure and possibly snap. but with larger bumps it would stop the shock from compressing all the way and avoid the issue? I think I got it now haha
    Gettin Lost and c4lvinnn[QUOTED] like this.
  14. Jul 2, 2017 at 5:41 PM
    c4lvinnn
    Well, the spacers INCREASE up travel of the whole suspension, but the shock didn't gain any. So you're over compressing the shock which overloads it.
    cchicoine[QUOTED] likes this.
  15. Jul 2, 2017 at 5:42 PM
    #35
    cchicoine
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    Thanks, just trying to ingest everything haha
  16. Jul 2, 2017 at 5:43 PM
    #36
    c4lvinnn
    Sorry I edited my post. but you have the basic idea.
  17. Jul 2, 2017 at 5:44 PM
    #37
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    Saw this on the dude's instagram.... sucks:anonymous:
    Reasearch should always be done before messing with suspension, or any type of mod. :boink::crapstorm:
  18. Jul 2, 2017 at 5:45 PM
    #38
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
  19. Jul 2, 2017 at 5:46 PM
    #39
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I got an idea, let's take pics off another members Instagram page and post it here, tag him and let everyone call him an idiot.
    Fucking great thread. I'm sure he already felt like an idiot when t happened, let alone now that he has to come on to read this shit
  20. Jul 2, 2017 at 5:48 PM
    #40
    MilkTeacoma
    MilkTeacoma Well-Known Member
