When Tacoma for 2 minutes with no oil I am such an idiot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MRPVette, May 1, 2025.
  1. May 1, 2025 at 9:45 PM
    #41
    tomatogrower
    tomatogrower Well-Known Member
    2013 tacoma crew cab 4x4
    none
    what's done is done... toyota trucks are tough and durable... sounds like you dodge a bullet... i've had a company chevy S-10 suv's engine lock up and seize from lack of oil on the Ontario freeway in Los Angeles a number of years back... quite the unpleasant experience... never forgot that sound... i've done more idiotic things in life than you... my brother is dumber than my dog... we're still here...
    Alex the Great likes this.
  2. May 1, 2025 at 10:15 PM
    #42
    Waasheem
    Waasheem
    2007 xrunner
    I’d rather lose an engine than my job. Truly sorry for your loss. I’m sending positive thoughts your way hoping you’ll find a job better than the last.
  3. May 2, 2025 at 6:19 AM
    #43
    HoosierBuddy
    HoosierBuddy Well-Known Member
    Phil
    2012 Base Regular Cab 4WD Manual
    2" Lift
    This whole thread makes me rethink an engine rebuild I did on my kid's mustang after the oil pump locked up and he drove it home with no oil pressure.
    Of course, since the engine had to come out to replace the oil pump, maybe I did do the right thing to go ahead and have it rebuilt.
    No way to tell now.
  4. May 2, 2025 at 11:06 AM
    #44
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    The only objective data to help determine will be sending oil off. Everything else is a guess.
    2015WhiteOR and BabyBilly like this.
  5. May 2, 2025 at 11:09 AM
    #45
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    What oil? :rimshot:
  6. May 2, 2025 at 11:37 AM
    #46
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Makes me think how many times this may have happened while our vehicles are in for an oil change and nothing is said.
  7. May 2, 2025 at 11:45 AM
    #47
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    This, and stories of poorly reinstalled caps and plugs, is why I will never take mine to a shop. The one time I did, I checked both those things before even getting in.
    O'DubhGhaill likes this.
  8. May 2, 2025 at 11:48 AM
    #48
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Reminds me of a car I took in, years ago.
    One week before a road trip I had the oil changed.
    The day before the trip I was fueling up. While washing the windows I noticed some oil on the bumper. Opened up the hood and the entire underside was covered in oil.
    They forgot to put the oil cap back on.
    They tried to say it fell off. Only there wasn't any room for it to fall off. In the very rare event that the cap would have fallen off.....there is no place for it to fall.
    The car wasn't showing any signs, that week, other than running warmer than usual.
    It was an old car in the summer.
    Ran fine the rest of the time I had it.
  9. May 2, 2025 at 11:50 AM
    #49
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Did you cause damage? Not really. Not likely.
    Was there wear on the engine when it ran? Yes - there always is.
    Did you cause more wear than a standard lubricated 2 minute run? Yeah, probably. But if you caused 10X the wear then that 2 minutes felt like 20 minutes of lubricated running. So you only shortened the life of your engine by 18 minutes. Is that really enough of a difference to make a difference? No.
    It's Friday. Pop a cold one and kick back. You have committed no mortal sin that you can't be absolved of by just letting it go.
    Hook78 and O'DubhGhaill like this.
  10. May 2, 2025 at 2:55 PM
    #50
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    My dad once filled up his diesel truck with E85. Truck had 1/4 tank of diesel before filling up. He drove that poor truck from the gas station pulling a 6k trailer until it died and costed it off the side of the road where he tried to start it over and over. In his defense the handle at that gas station was green for E85 which is usually diesel but still. I drained the tank, put a quart of trans fluid in the tank with new diesel and then filled the fuel filter with trans oil. Put 10k miles on it before they sold it with no issues. Good ol reliable ford 6.4 (kidding it was on its second motor when that happened)
    Torspd likes this.
  11. May 2, 2025 at 5:21 PM
    #51
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Scary! But should probably be fine like the others stated.
    In the future, when you startup after an oil change stay in the vehicle and first watch to make sure the oil light goes off, then go check for leaks. Confirming oil pressure is always the first thing I do upon start up for oil changes.
  12. May 2, 2025 at 5:22 PM
    #52
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    The oil he filled it up with after. Any metal would be in it.
  13. May 2, 2025 at 5:27 PM
    #53
    Shotgun Clay
    Shotgun Clay Well-Known Member
    Jiffy Lube is hiring. (I couldn’t help myself, sorry.)
    ChessguyTaco likes this.
  14. May 2, 2025 at 7:46 PM
    #54
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    It's was a joke :cheers:
    photodoc[QUOTED] and Torspd like this.
  15. May 3, 2025 at 5:28 AM
    #55
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Harsh, but fair.
    A friend had a really nice 1989 Camry with about 183,000 mi on it. It was still in great shape. He brought it into jiffy lube one day for an oil change and being jiffy lube they didn't have the right filter so put on one that was close. It just wasn't close enough and it pissed out all of the oil on his way home. That was the end of that. And of course they said it wasn't their fault he didn't have the money for a lawyer.
  16. May 3, 2025 at 6:41 AM
    #56
    Waasheem
    Waasheem
    2007 xrunner
    My first motorcycle was a yamaha 2 stroke twin. I used it for a year then decided to change the oil. 2 drops came out, it ran better with oil in it. Live and learn.
    2 strokes use oil with the gas, in its case, injected oil. So the top was getting lubed.
  17. May 3, 2025 at 7:43 AM
    #57
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    The one time I went to a Jiffy Lube, I had them install an exhaust system. I don't recall why I chose them over a real shop. (I think it was the only place that didn't care I brought them a tin can with a screen for a cat)
    They actually did a ok job installing the exhaust, but they used the rear floor boards to jack up the car :facepalm: They were dented just enough to pop the drain plugs. I knew nothing about it until the first time I drove the car in the rain afterwards.
  18. May 3, 2025 at 6:01 PM
    #58
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    Yeah my bad I missed it.
  19. May 3, 2025 at 8:23 PM
    #59
    ChessguyTaco
    ChessguyTaco Well-Known Member
    L
    :rofl:I was thinking about the same thing.
  20. May 4, 2025 at 4:02 AM
    #60
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Like has been stated, you can never get all the oil out of any engine. You had it under zero load and it’s a Toyota. Nothing to see here.
