WHEN TO CHANGE MANUAL TRANSMISSION FLUID
Discussion in '1st Gen. Tacomas (1995-2004)' started by swoagman, Mar 25, 2012.
  1. Dec 13, 2013 at 10:18 AM
    Madjik_Man
    Colorado Front Range
    I had to gravity fill my transmission the first time when the POS plastic pump I had shit the bed after 1/2 a quart
    GQ7227 likes this.
  2. Mar 9, 2015 at 11:49 AM
    riddmkidd
    riddmkidd Member
    Damien
    SF Bay Area
    v6 4x4 xtracab
    Reviving this thread because I just went to the local dealer and their system says to use gl5 in my manual transmission and transfer case. You guys claim it eats brass syncros. Think I'm going to look for redline.
  3. Mar 9, 2015 at 11:56 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Redline in my transmission shifted like shit, hard to shift when cold and always felt like i was dealing with more resistance getting in into gear, Do not recommend!!!!
    I use off the shelf mobile 1 or prestone 75w-90 synthetic in the front diff, transfer-case and transmission and its perfect.
    Going to upgrade my rear diff to 75w-140 soon too.
    I keep a detailed log of any and all maintenance I do to the truck down to the mileage and date and what was done.
    GQ7227 likes this.
  4. Mar 13, 2015 at 5:15 PM
    riddmkidd
    riddmkidd Member
    Damien
    SF Bay Area
    v6 4x4 xtracab
    anyone tell me the torque settings for the transfer case bolts? I can't seem to find it in my manuals. Also for the transmission fluid case too.
    Ooh found it! 27ft lbs.
  5. Jan 14, 2016 at 7:57 PM
    2studley2
    2studley2 Member
    Jeff
    99 Tacoma TRD SR5
    How much gear oil for tranny?
    Also, how much for dif?
  6. Dec 3, 2016 at 4:33 PM
    Wave808
    Wave808 Member
    Tucker
    kauai
    98 tacoma
    icon 3" lift 285-75-16 tint clears and chrome
  7. Jun 29, 2020 at 1:02 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    So what should I buy for my manual 97 5 speed gear oil wise? Not really sure and they only have gl-5 as I can see at my local oreillys
    GQ7227 likes this.
  8. Jun 29, 2020 at 1:04 PM
    04tacoma trd
    04tacoma trd Well-Known Member
    I used all synthetic in front/rear diff, xmission and xfer case
  9. Jun 29, 2020 at 3:00 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    holy thread resurrection batman. Did you not find your answer when you were clearly searching?
    Redline MT90
  10. Jun 29, 2020 at 3:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    Post 16 tells you how to obtain the factory manuals you apparently don't have.
    The GL rating and viscosity are more important than the brand.
    cruiserguy likes this.
  11. Jun 29, 2020 at 4:46 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    :notsure:
  12. Jun 29, 2020 at 4:55 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    felt the same to me as any other oil - but it's GL4 so there's that
    GQ7227[QUOTED] likes this.
  13. Jul 1, 2020 at 11:14 AM
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    So redline mt90 then? It gets quite cold where I live so maybe not?
  14. Jul 1, 2020 at 2:23 PM
    TacomanTurd
    TacomanTurd Well-Known Member
    David
    2004 Tacoma
    Stock for now
    Ok, this is my own observation on multiple third gen 4runner and first gen Tacoma. All with 3.4l V6 some manual and some 5speed transmission.
    the only oil in the drive train that need change regularly is the rear diff.
    I usually buy my vehicles right around 100k miles or lower. Every time I drain the transfer case, transmission and front diff, the fluids in those three are still clear enough to see thru. The one in the rear diff is always black. And no matter what oil I use, the 5speed is always a pita to get in first gear.
  15. Jul 8, 2020 at 3:20 PM
    #35
    Nervo19
    Nervo19 Well-Known Member
    Have you changed your shift bushings? I got them from MarlinCrawler.com. Pretty easy.
  16. Jul 8, 2020 at 3:36 PM
    #36
    04tacoma trd
    Same here, except reverse gear
  17. Jul 8, 2020 at 4:30 PM
    #37
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    The color of oil isn't the only indicator. Viscosity can be changing (this is due to shearing) even if it still looks honey colored.
    Since the drivetrain doesn't get exposed to combustion and mostly shouldn't be running hot enough to actually burn the oil it might not ever get dark. The rear diff probably is the worst for being exposed to dirt and heat. Especially stock since they rarely have extended breathers. My truck's front diff and transfer have breathers in the engine bay so they won't suck in as much dust or water.
    My rear diff (like yours) and transfer case are the two that turn darkest in my truck. My transmission and front diff like yours don't usually get too dark.
    And even dirty looking oil doesn't necessarily indicate it's bad. The lubricants we use now have detergents that intentionally hold contamination in suspension, which is why it looks dark but it might still be fine. The best way is to test the oil to know but this isn't really practical to do for all 4 major components every so many miles (say every 10k) to get it exactly right so it's just easiest to follow the schedule Toyota recommends.
  18. Jul 9, 2020 at 7:02 AM
    #38
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
