When to change rear brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ecr6cyl10, May 22, 2015.
  1. May 22, 2015 at 9:02 PM
    ecr6cyl10
    ecr6cyl10 [OP] Well-Known Member
    Eddy
    Gilbert, AZ
    10 Prerunner Dble Cab Offorad
    Defiant Light bar with 12" LED light bar and 2 Rigid dually floods. 3" Icon lift in the front with TC UCA's and 1.5" add a leaf in the rear [url=http://www.tacomaworld.com/gallery/showphoto.php/photo/198098/cat/500][img]http://www.tacomaworld.com/gallery/data/500/medium/My_Truck54.jpg[/img][/url]
    i have a 2010 Dbl can prerunner lifted 3" lift and 33" bfg's with 98000 miles. When do you guys think I should change the rear brakes? I replaced the fronts at 70000.
  2. May 22, 2015 at 9:04 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    Definitely want to consider it when they hit the 3mm or less pad thickness.
    MTopp and lynyrd3 like this.
  3. May 22, 2015 at 9:08 PM
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Rohnert Park
    2016 TRD Sport AC 4x4 Super White
    B R A K E S
    MTopp likes this.
  4. May 23, 2015 at 7:10 AM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    Has anyone changed there rear brakes and is it that hard?
    MTopp likes this.
  5. May 23, 2015 at 7:24 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    There are vids on YouTube
    MTopp and Alexely999 like this.
  6. May 23, 2015 at 7:27 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Change 'em when they need it (according to material that's left).
    My previous tacoma had 110,000 miles on it when I sold it and I never changed the rear shoes. They had plenty of life on 'em.
    MTopp likes this.
  7. May 23, 2015 at 7:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    Of course they have. They don't last forever.
    Since you're asking, I'm assuming you've never worked on drum brakes before?
    If that's true, then it would be helpful to have someone with experience look over your shoulder and coach you through it. Only disassemble one side at a time, so you have the other side as a reference (although mirrored) if you can't recall where certain bits go. Another simple aid is to do some cleaning pre disassembly to show things well, and take a couple of clear photos.
    If my assumption is wrong and you have worked successfully on drum brakes before, then you'll be just fine.
    MTopp, wilcam47 and lynyrd3 like this.
  8. May 23, 2015 at 7:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    Any parts house should be able to give you the thinkness specs for the shoes/drums. HF sells budget measuring tools that will suffice for this application. If either is outside of spec, replacement is in order.
    If the drums have deep groves that the shoes get set in easily, replacement is in order
    If the wheel cylinders are wet on the ends, rebuilding or replacement is in order
    You don't say how you use the truck, just the mileage. If that's pretty much easy clean driving, rears will often last 1.5-2x the front, so you may be fine. But only an examination will tell for sure.
    At a minimum while you are examining, clean everything up (within reason, no disassembly other than the drum really needed), lube the appropriate points, and adjust the shoes, making sure the star adjuster works freely.
  9. May 23, 2015 at 8:35 AM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    Clearwater thanks for your help i haven't done drums before. I will check them and see what is left on the pads.
  10. May 23, 2015 at 8:30 PM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    Pull your drums next time you rotate your tires and take a look at them. Pick up a can of brake clean, and spray them things out real good. Lots of dust and gunk build up in there.
    My Ranger went many many thousands of miles and I never did nothing more than spray them out every once in awhile. Still had probably 50% life left on them.
    Your front brakes do most of the work
    MTopp and lo2hi like this.
  11. May 24, 2015 at 6:28 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    i changed mine at 125k and the drums were shot too, but not horribly. I'm sure by now the weights on your drums fell off as had mine. I never saw any adverse results from that happening.
    The drum setup is a bit odd as compared to all of the GM products that I was used too. Be sure to only do one side at a time so you can see how the other side was originally.
    Be aware that these drums are about $110 each, that's right, each. Also be forewarned that at 125K my e brake cables went and caused those new brake shoes to be destroyed and I had to have the brand new drums cut. That all happened in about 5k after all of the work was done. The dealer charges $450 to replace the ebrake cables, a job that I would typically do myself, but it was all about the timing.
    The symptoms of the bad cables was not something that I had experienced before. My brakes started grabbing and one side started to lock up on heavy breaking. I had convinced myself that I had done something wrong during my brake job and had taken everything back apart again but found nothing. I had to go to the dealer for something and I asked him to check it for me, that's when it was determined that the e brake cable was the cause.
    MTopp likes this.
  12. May 24, 2015 at 8:23 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Have done disks several times, but I have a shop do drums. Noticed the shop does it this way, and would look at the other side a couple of times doing re-assembly.
    MTopp likes this.
  13. May 24, 2015 at 8:40 AM
    marshall765
    marshall765 Well-Known Member
    Shreveport Louisiana
    13 DCSB TRD Offroad 4x4
    I have changed my last 2 trucks rear drum brakes at 100K, and they had another 30k left on them.
    Drum brakes are not hard, but way more complicated than disk brakes up front. Watch the videos, and take pictures during disassembly and you will be fine.
    The first set of drums I did I had a hard time putting back together (I had to phone a friend!) wish I would have had a camera phone back then.
    MTopp and TacosNBurritos like this.
  14. May 24, 2015 at 3:45 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Before I got my rears replaced, I pulled the hub and noticed that they were thin on the one side and never having done them before I went to a shop. I told the guy I need the rears done and it was like he didn't believe me. He called me up and was like "yeah you really do need rears" No shiat, I wouldn't be there if I didn't. Ended up having to pull one of the hubs after I heard a strange sound. Tech didn't put one of the springs in place right when he did them. Went online and saw how it was supposed to be put in and put it in. I decided to pull the other hub to take a look, the shoe retractor wouldn't budge. It was frozen in place. Popped off the hub using the bolt holes and the springs that hold the pads in place popped off and ruined the spring caps. Ran to Pepboys and found some springs that would work and put them on. I then cleaned both sides and freed the stuck retractors and reinstalled them. To sum up, they are not hard but kinda confusing, watch vids and leave the other side untouched until the first is done. I won't ever use that shop again.
    MTopp likes this.
  15. Sep 9, 2017 at 2:05 PM
    TacosNBurritos
    TacosNBurritos Active Member
    Nick
    Pacific Northwest
    2012 4x4 T|X TRD
    I read that drum brakes are designed to last for 200,000 miles. After taking off the drums today to look at the pads, they is about 75-80% pad left! I was shocked. I bougt new pads and springs. I just replaced my front brakes for the first time 2 weeks ago. Toyota builds them tough! I have 98K miles. I'll check them in about 30K miles to see how they are doing.
    Also, I thought it was odd that Toyota had to order rear brake parts. I guess they don't change rear brakes much.
    MTopp likes this.
  16. Sep 9, 2017 at 2:15 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Mine still look new with 84k on the odometer. I just clean and adjust them every now and then.
  17. Sep 9, 2017 at 3:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    My last truck was 20 years old and still had the original brakes all around. I don't remember the last time I needed to replace rear shoes on a vehicle. My wife's 1998 Sienna Van still had the original rear shoes when we sold it it had 200K Miles on it.
  18. Sep 9, 2017 at 5:31 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    I only changed mine because the rear axle seal was leaking and I had the seal replaced. At about 100K miles, the shoes still had plenty of life in them, but were soaked in gear oil.
    Changing them was not overly difficult for the first time with drums. I found the Chiltons manual easier to understand than any of the youtube videos or service manuals.
    It did take me awhile to get adjusted as none of the do a handstand, suck your thumb, blindfold yourself, and back off 15 clicks crap worked for me.
    MTopp likes this.
  19. Sep 9, 2017 at 5:43 PM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Drum brakes are so maintenance free. Very normal to go 150k with just a little occasional cleaning. When it comes time for replacing, take both drums off but take apart only one side at a time. I've done drum brakes a dozen times over the years and still like to check the other side while assembling. They last so long it's worth replacing both shied and drums together.
  20. Sep 9, 2017 at 5:46 PM
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    If your axle seal is leaking, check the diff vent for blockage. If it is, high temps can increase pressure and force oil past seals.
