When to change rear shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toughbuff, Jun 10, 2014.
  1. Jun 10, 2014 at 2:25 PM
    Toughbuff
    Toughbuff [OP] Member
    SE WA
    TRD Off Road
    I have a 2011 Double Cab 4WD TRD SR5 i bought with 62K miles. The rrear shocks seem fine but seem to sag quite a bit when I loaded my 400lb motorcycle in the bed. How would I know when I need to change the rear shocks.
  2. Jun 10, 2014 at 2:58 PM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    It's the rear leaf springs that are crap. They were not ment to carry a load. Might have to get an add a leaf to help support the laid you're carrying
  3. Jun 10, 2014 at 5:09 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    X2
  4. Jun 10, 2014 at 6:26 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    x3, shocks are there to maintain tire contact with road. Springs support weight of truck and contents. Gas pressure shocks last quite a while compared to older styles. Rears last longer than fronts. In the old days on a 4x4 I would replace at about 50. As with other things it depends on how you use truck and roads you drive. Lots of driving on washboard roads will shorten life.
  5. Jun 11, 2014 at 12:20 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Ride Rite Air Springs (Bags) will fix it. I had them on my '05 with the crapo rear springs... and my 2010 was fine until recently and now I am feeling bumps I did not before (63,000 miles)... Will put the Ride Rites on my 2010. Upgrading the rear shocks to Bilstein 5100s also may be in the works.
  6. Jun 11, 2014 at 1:20 AM
    TacoScoob
    TacoScoob Active Member
    San Mateo
    6" pro comp lift. Wrangler duratracs. Pro Comp ES9000 shocks Full metal jacket bed cover Led interior mod Satoshi grill
    Yup. Firestone ride rite airbags are what I needed on my last rig. Needed to support over 400 lbs daily for work hauling stones etc for a landscaping job. I combo'd with bilstein 5100, which also leveled and added 2", and the 400 lbs load felt like a pile of feathers. Plus the air bags and 5100's are adjustable depending on load which is super sweet.
