When to change UCA
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mexanese.502, Mar 9, 2020.
  1. Mar 9, 2020 at 7:13 PM
    mexanese.502
    mexanese.502 [OP] Well-Known Member
    Kentucky
    2017 Limited BADASSMF
    OV Tuned
    Just had the medium load Old Man EMU 2" coilover an leafs installed. Now looking at tires.
    However it seems any larger of tire will start rubbing the UCA. Mine has the 18" Limited wheels, and I've already moved from 265/60/18 to 265/65/18.
    Do I need to upgrade the UCA for taller tires?
  2. Mar 9, 2020 at 7:15 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    If you are rubbing the OEM UCA you need new wheels or spacers
    tcjacado likes this.
  3. Mar 9, 2020 at 7:16 PM
    tcjacado
    tcjacado Well-Known Member
    This^^^^^^
  4. Mar 9, 2020 at 7:17 PM
    mexanese.502
    Kentucky
    OV Tuned
    No rubbing now but anything larger than the 265/65/18 looks like it will.
  5. Mar 9, 2020 at 7:34 PM
    50ate
    50ate Well-Known Member
    Washington
    2019 OR DCSB 6spd
    Wheel offset is your problem
