When to do 1st Oil Change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bu11etWhisperer, Mar 17, 2010.
  1. Mar 17, 2010 at 5:48 PM
    Bu11etWhisperer
    Bu11etWhisperer [OP] My Taco is Blue!!!
    Mark
    Douglasville, GA
    2010 Prerunner, SR5, TRD Sport, Speedway Blue
    Hey Y'all,
    I just bought my 1st Taco last Sat. on the 13th of Mar. My question is what mileage do I have to do my 1st oil change? Is it like my bike where as they recommended an oil change every 3000 miles but the 1st one had to be at 500 miles :confused:. Now I know the dealer told me Toyota recommends the oil change every 5000 miles but they didn't mention anything about the initial change and I am afraid they may have forgotten to mention it. I just don't want any shit from the dealer if something does go wrong with my Truck :eek:. I scoped through the OM but didn't see any info but it's possible I over looked it.
    Thanks;),
  2. Mar 17, 2010 at 5:49 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    just do what the manual says.
  3. Mar 17, 2010 at 6:04 PM
    olgzr
    olgzr Well-Known Member
    Denton, Tx
    What you have to do is change it per the manual, no early change required. Many people do change the oil at 1000 to 2000 miles and then go to the 5000 mile change interval. I changed mine just before 2000 miles.
  4. Mar 17, 2010 at 6:35 PM
    Bu11etWhisperer
    Mark
    Douglasville, GA
    Thanks for the replies. I will follow the manual suggestions. I've just always been told that a new motor has metal pieces and trash in the 1st tank of oil. This causes scaring of the piston walls and more problems down the road. No worries though. Thanks for the advice.
    Thanks again,
  5. Mar 17, 2010 at 9:02 PM
    delscorcho
    delscorcho Well-Known Member
    Yorba Linda
    09 DC LB SR5, Black Sand Pearl
    30% Tint, Weathertech Floor Liners, Transmission TSB, Leaf Spring TSB, 1" Front lift, FJ Alloys, 265/70/17
    5K is probably fine but I did my first at 1K.
  6. Mar 17, 2010 at 9:06 PM
    eskamo23
    eskamo23 Well-Known Member
    Pasadena, CA
    trd sport
    TRD cai with (AFE dry flow filter), de-flapped, tint, weathertech floor liners,coverking neoprene seat covers, rear TSB, Billy 5100's set at 1.75'', Pro Comp 7005's 17x8 BS4.5, any time fogs, tailgate theft mod, led lights in the int., slim cubby HID headlights and fogs, TRD skid plate, bed mat
    i did mine at 3k. now ill wait untill its at 8k, maybe....
  7. Mar 17, 2010 at 9:08 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    i did my first at 500mi. and then every other about 3k intervals. mobil 1 full synthetic.
  8. Mar 17, 2010 at 9:11 PM
    lowzone
    lowzone Well-Known Member
    Ron
    Earth aka NJ
    2010 MGM AC 2.7L 5 spd SR5
    future plan of 2" drop and any type of rim thats not a steelie. grille and BHLM mods, maybe....
    the only thing i can put thats worth anything is that the motor DOES seat the rings and valve guides. NOTHING is that precise thats mass produced like a vehicle. The FILTER catches the particals, so IF anything, you should do an oil change at around 1000 miles since MOST of the wear has occured in the seating of the rings and other parts. the Babbet on the bearing surfaces get the clearances set and there are particals due to this. Again, the filter catches these particals and thats its purpose. you COULD go 5000 miles but in all reality, i would worry more about the filter clogging and the BYPASS valve (if the OEM filter has one) opening up and just recirculating crap thruout the motor. Thats why i change my oil every 4000 miles regardless of how it got there or how long (synthetic all the way) and drop my first oil around 1000 miles. i will use Toyota Filters, i only have 780 miles on my 2010 Taco AC and will use OEM filters for warranty purposes and they are some of the best filters (manufacturer filter) on the market.
  9. Mar 18, 2010 at 5:32 AM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    did my first at 500 miles.
