When to get fluid film applied?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fgeorge097, Jul 29, 2018.
  1. Jul 29, 2018 at 9:25 AM
    fgeorge097
    fgeorge097 [OP] Well-Known Member
    Northeast
    2018 OR AT
    Live in eastern PA - wondering when the best time is to get applied?
    Should it be applied in the dead heat of summer to let it settle in?
    Or in the fall, a couple weeks before snow season approaches?
    Also, do I have to keep the truck inside for a few days while the fluid film is settling in? I am not sure if it rains, if that will have a negative effect on the application.
    I have been through many of the threads on this and there does not seem to be consensus.
  2. Jul 29, 2018 at 9:29 AM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    I apply right before they salt the roads so it lasts through the winter
    Vbpiper likes this.
  3. Jul 29, 2018 at 9:34 AM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    I usually try and apply in the fall, say October or so, but I also hear of some who apply spring and fall, which I've considered. I don't see any point in leaving it set inside for any amount of time, I just get right back to using the truck. It never really solidifies, it stays a bit goopy, but I'm pretty liberal in my application of it. You'll smell it burning off the exhaust system for a while at stop lights, but I kinda like the smell. Really make sure you get the parts of the frame behind the front wheels and at the joint to the crossmember right there that part seems to take the most abuse.
    poseytaco and Vbpiper like this.
  4. Jul 29, 2018 at 9:36 AM
    tonestar
    tonestar Well-Known Member
    Anthony
    NY
    2015 Taco 4x4 V6
    I apply twice a year, rust and humidity also happens in the summer- it’s not just the salt. Apply it ASAP and repeat in 6 months
  5. Jul 29, 2018 at 10:03 AM
    fgeorge097
    Northeast
    2018 OR AT
    So, apply now, then again in January/February?
    The installer said they would give me a 'touch-up' for a cheaper price...Maybe I should get the full installation now and then the touch-up in Jan/Feb?
  6. Jul 29, 2018 at 10:38 AM
    tonestar
    Anthony
    NY
    2015 Taco 4x4 V6
    Buy 2 cans at Lowes... very easy to spray- look up other rusted Tacoma’s and you get a good sense or where’s it needs to be applied (main focus on the entire frame)
    Wear a painters mask and goggles and you’re golden
    Vbpiper likes this.
  7. Jul 29, 2018 at 10:44 AM
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    It’s funny because I couldn’t stand the smell when I first used fluid film. Now I like the smell too. I use at least 4 cans when I apply it.
    Vbpiper likes this.
  8. Jul 29, 2018 at 10:45 AM
    Muldoon
    Robert
    Northeast Ohio
    I figured if I went for the twice a year thing I'd do Octoberish then Aprilish. Don't worry too much. I think once a year would probably be enough if you get the truck new and apply every year as a preventative, never should see rust. But I got my truck after it had already seen 6 unprotected northeast ohio winters so there's some rust under there but it's not too bad. Just want to ensure it doesn't spread.
    Vbpiper likes this.
  9. Jul 29, 2018 at 10:47 AM
    Muldoon
    Robert
    Northeast Ohio
    I just buy it by the gallon and use a bunch. I do inside of the boxed portions with Eastwoods rust encapsulator. Saw that on a thread here and went with it. Not sure if it's any better or worse than fluid film for that application.
