When to install a supercharger.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by QueTaco, Mar 16, 2015.
  1. Mar 16, 2015 at 12:49 PM
    QueTaco
    QueTaco [OP] Member
    Canada
    2015 DCSB Trail Teams, SC, 6 speed
    Supercharger
    Hello Taco Gods.
    I have taken delivery of a 2015 DCSB 6 speed. I intend to have a supercharger installed ASAP. The problem is how long is ASAP? Should I have it installed now (my preferred choice), or would it be better to wait till the first oil change (5000 miles) and go through another break-in period.
    I would like to get some of your opinions on the matter.
    Thanks guys. Always interested in reading all the different opinions and suggestions.
    Quetaco.
  2. Mar 16, 2015 at 12:56 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Vehicles today do not have the same break in requirements as in years past. Also some vehicles come with a turbo or SC so you might as well do it now.
  3. Mar 16, 2015 at 1:00 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Just do it! Best mod I've ever made.
  4. Mar 16, 2015 at 2:22 PM
    Mongo1958
    Mongo1958 Well-Known Member
    Van
    Newnan, GA
    2015 Bright White Access Cab w/convenience pkg.
    Carbon filter removal. Intermittent Wiper Stalk. Cruise Control. Fog Lights.
    How much?
  5. Mar 16, 2015 at 2:25 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    I waited 5 moths. But could of got it done once I wrote that massive cash check.
    No reason not to get it done right away.
    Read about finding the best price and make sure you pick a dealer that has done many of them. If your in Dallas go here.
    Toyota of Dallas
    http://trdparts4u.toyotaofdallas.com/scripts/openExtra.asp?extra=5
    Mine out the door in Las Vegas was almost $6k. I could of got it done for less, maybe $5.2k but finding the right dealership matters. Talked to the tech etc, they gave me a rental. Dropped off Monday, picked up Thursday.
  6. Mar 16, 2015 at 2:28 PM
    Conumdrum
    Las Vegas
    2014 Tacoma
    I have the extended warranty, +5 years, so with Toyota install it's covered for 8 years.
  7. Mar 16, 2015 at 2:52 PM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    I just had my supercharger installed with 280 miles. Not worried about it.
  8. Mar 16, 2015 at 2:58 PM
    smuggiesrider
    smuggiesrider Well-Known Member
    Vermont
    2021 Army Green TRD Off-Road DCSB AT
    TRD 2" Lift kit w/ PRO Grille swap package ARE CX Classic Cap Sumitomo Encounter AT 265/75/16 tires TRD Pro wheels Predator steps Frame salt protection spray Weather Tech floor Mats and rainguards Wet Okole Seat Covers Bedmat Black exhaust tip Bed light LED kit Tailgate mat Eyecatcher tailgate letters Yoda cover for tow hitch and steering wheel Decals for grille, glove box, badges $$$$$$
    What's the latest you should install?
    I'm thinking if installing on 2010 with 72k miles.
    All on Mobil 1 changed every 4k miles
  9. Mar 16, 2015 at 3:14 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    What's the going rate for a Supercharger on the Taco 4.0? I imagine it's more money than I want to spend!
  10. Mar 16, 2015 at 3:15 PM
    Conumdrum
    Las Vegas
    2014 Tacoma
    Read post 5.
  11. Mar 16, 2015 at 3:42 PM
    Conumdrum
    Las Vegas
    2014 Tacoma
    RockL installed his, labor can be from $900 to $1500, depending on the dealer. It's a 10 hr install, if not more, depending on the experience of the tech.
  12. Mar 16, 2015 at 3:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    A compression test and a lab oil analysis would be a cheap way to verify the internals are healthy.
    If it passes muster, go for it.
  13. Mar 16, 2015 at 4:50 PM
    Brjw
    Brian
    $4900 installed at the dealer.
  14. Mar 16, 2015 at 5:00 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    exactly.
    Buddy bought his with 16mi on the clock with the supercharger installed from the dealer before he even picked it up.
  15. Mar 16, 2015 at 5:02 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    You think so? My first engine oil analysis was chock full of metal. 2nd was leaps and bounds better, but still out of specs in 2 areas.
    I expect the 3rd to be perfect, but don't just assume your engine is broken in when you buy it. Here are the two reports from Blackstone: 4500 miles
    There is a lot of metal here, but don't worry. High wear is perfectly normal in new engines. The metals are
    simply coming from new parts wearing in, and they should improve greatly over the next 2-3 oil changes. Eventually
    things should look like universal averages. They show typical wear levels for this type of engine after about 5,500 miles
    on the oil. Silicon is from harmless factory sealers, and that should wash out too. The viscosity is in the 5W/20 range,
    but that won't hurt anything. There's no fuel or coolant here. Just check back to monitor progress.
    9625 miles: We were looking for improvements in this sample and this oil did not disappoint. Copper has improved to just
    24 ppm and silicon is down to 71 ppm. Both readings are still elevated, but they should continue to improve from here,
    so we'll just look forward to that next time. Other metals have already improved nicely, so this engine has made some
    great progress overall. The viscosity was fine and no fuel, moisture, or coolant contamination was found. Insolubles,
    which are oxidized solids caused by heat, use, and/or blow-by read nice and low at just 0.1%. Looks great!
  16. Mar 16, 2015 at 5:23 PM
    Conumdrum
    Las Vegas
    2014 Tacoma
    Add tax and environment fees, gallon or two of antifreeze, shop rag fees. Still an awesome price.
  17. Mar 16, 2015 at 5:28 PM
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I don't have a SC, and it was the factory oil... which was 5W30 and after 4500 miles had broken down to 5W20 viscosity.
    My point is, does the factory actually "break in" the engines. When do they do this? How many "miles" do they put on the engine? Do they hook it up to a Dyno before or after they put it in the truck?
    Does that even sound reasonable? Aside from making sure it works properly, I don't think they do anything else but drop it in the truck and roll it out.
    I don't know for sure, but in my experience with the 2 oil samples taken on my truck it sure doesn't look like the engine was "broken in at the factory".
    I'm not trying to be argumentative, and I'm not trying to be a dick, but does it sound reasonable that a car manufacturer would "break in" an engine? And as I asked above, when do they do this? How do they do this?
    Judging by the oil samples on my own truck, it's either not true, or was certainly not done to my truck's engine.
  18. Mar 16, 2015 at 5:32 PM
    Brjw
    Brian
    Nope $4900 even, out the door. And they gave me a loaner for a couple days while doing the work. And added octane boost to my tank. No taxes here though.
  19. Mar 16, 2015 at 5:34 PM
    Brjw
    Brian
    So you want the manufacturer to put the equivalent of 10k miles and two oil changes on the engine before buying it? Define "breaking in", if so.
  20. Mar 16, 2015 at 5:52 PM
    nd4spdbh
    SoCal
    the manual never calls for 20weight in the 1GR.... unless you live in a real cold climate.
