When to torque front struts
Discussion in 'Suspension' started by Sean42, Sep 24, 2021.
  1. Sep 24, 2021 at 9:45 AM
    Sean42
    Sean42 [OP] Well-Known Member
    I installed 3rd gen struts on my 2011 Tacoma. I realized after the fact that I torqued the upper and lower nuts while the car was in the air. I’m learning now that ideally this is done on the ground to not cause excessive tension on bushings and other parts. Truck seems super stiff up front, could that be why?
    And also if I were to fix it then what’s the move? Lift the truck, loosen, lower it then retighten?
  2. Sep 24, 2021 at 9:55 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Torque on mounting bolts has nothing to do with stiffness of Stock struts. If its stiff its cuz they are new.
  3. Sep 24, 2021 at 10:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    No.
    The goal is to torque bolts that rotate within bushings with the component in compression, not in droop.
    So the top of the shock doesn't matter, but the bottom does. And the LCA bolts if you had them loose/out for the install, etc etc.
    Simple way is a drive on ramp that lets you get to everything while in compression. Loosen, retorque.
    If a driveway job, lift, jack stands, then loosen. Then put the jack under the LCA and lift till the truck starts to move. That should be enough compression to torque properly.
  4. Sep 24, 2021 at 10:38 AM
    Sean42
    Thank you for the reply. I took apart the upper control arm. I’m assuming that should be redone?
  5. Sep 24, 2021 at 10:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yes. Any 'joint' that has a bolt through a bushing that rotates.
  6. Sep 24, 2021 at 10:45 AM
    Sean42
    Last question. What is the potential failure or damage that can be caused since I torqued it at droop if it’s not repaired?
  7. Sep 24, 2021 at 10:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    Depends on how bound the bushings are.
    It's worth doing right to me.
    Sean42[OP] likes this.
