when to use the locking rear diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, May 25, 2011.
  1. May 25, 2011 at 8:35 AM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
    So I am looking at an 05 tacoma prerunner 2wd with the trd off road package. when can I use the locking rear diff. I imagine that the only time I would need to use it would be when we get alot of snow, which isn't very often. 1, maybe 2 times a year.
  2. May 25, 2011 at 8:37 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    Only if you're stuck. IIRC you can only drive like 3mph with it engaged. Or that's whats recommended.
  3. May 25, 2011 at 8:38 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You can drive 50 mph and it wouldn't matter, only if you are driving in a straight line :D
  4. May 25, 2011 at 9:18 AM
    ericb
    ericb I'm a very neat monster
    Dexter
    surface of the sun
    Truck So Good
    rockcrawling
  5. May 25, 2011 at 9:28 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    right before you think you will get stuck without it.
    i think you need to be crawling when you go in, but you can drive over 5mph once you are in..
  6. May 25, 2011 at 9:29 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^This. Use it before you get stuck so you won't.
  7. May 25, 2011 at 9:31 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I turn it on as soon as I hit dirt, and I have gone around 50 mph for countless times, turning and catching air, and it's fine. Just make sure its off when u hit pavement
  8. May 25, 2011 at 9:32 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    win
  9. May 25, 2011 at 9:35 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2007 TRD O/R PreRunner DCSB Mid Travel
    I use my locker everywhere and for everything and I engage it doing doughnuts at full speed while hitting the NOS. It clunks pretty loud, but I think it makes me C00L3R that way
    engage it between 0-5mph, I use it whenever I am offroad and disengage it just before returning to pavement. zero issues so far.
  10. May 25, 2011 at 11:21 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    Lockup the rear diff if you're on a very rocky or dicey section of trail where maximum traction is needed and any wheel spin/slip may present some danger. I agree with aficianado, that using it in anticipation of getting stuck is also very good.
    The Toyota owners manual advises you to use it when you're stuck and to disengage it when your truck is free. That's good but sometimes if your stuck it may have trouble engaging.
    Welcome to the forum! :wave:
  11. May 25, 2011 at 11:25 AM
    TacomaPrime
    Greg
    Illinois
    So is the locking diff basically going to be worthless to me on roads that have alot of snow on them?
  12. May 25, 2011 at 11:29 AM
    TacomaPrime
    Greg
    Illinois
    would a limited slip be better for that situation?
  13. May 25, 2011 at 11:30 AM
    TacomaPrime
    Greg
    Illinois
    oh. and I consider myself a good driver, but this will be my first pickup. I am used to the full time AWD of my WRX with snow tires. that thing was damn near invincible in snow.
  14. May 25, 2011 at 11:40 AM
    JKD
    JKD Well-Known Member
    You might be better off with a 4wd. Yeah, more expensive, but...with what you're coming from, I think you will be happier with a 4wd.
  15. May 25, 2011 at 11:54 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    ^^^ This. Good limited slip in snow country is better option just because it adjusts to conditions on the fly.
    When it snows most of the road will get covered by ice/snow then there are spots (like under the bridges that have clean asphalt for the moment. The same thing as with AWD vs 4x4. AWD is more convenient then 4x4 due to ability to better manage changing conditions. But when going gets really tough then lockers are the way to go.
    IMO for winter: AWD (with center lock) + Lockers is best, 4x4 + good LSD is second.
    For 2wd I would think about Limited slip rather then locker. IMO Locker makes little sense for 2wd. Hard to rock crawl with 2wd and if there is a lot of snow to warrant locker most likely it won't make too much of the difference. (Unless you are on 100% flat area)
    Now to add to that. Not all AWD are created equal. open diff style AWD are not much help either but the ones with Limited slip in the center are pretty much perfect.
    If you switching from AWD to 2wd (Rwd) pickup you may be very disappointed. Not having ability to point wheels with power to desired direction is the main issue with 2wd pickups.
  16. May 25, 2011 at 12:00 PM
    TacomaPrime
    Greg
    Illinois
    Well, my wrx WAS going to be my weekend warrior and I was going to autocross it. that never happened, and I am sure I never took advantage of it's full potential. This truck will only be used to get me back and forth to work and around town. Maybe a trip up to minnesota 1 time a year and down to indiana 1 to two times a year.
    I figured the 4wd wouldn't be worth it to me.
  17. May 25, 2011 at 12:12 PM
    BlueT
    NorthEast
    I was referring to puerly snow driving. WRX is much better then pickup in 2wd for snow covered roads. Even if you have locker or Limtied slip in 2wd pickup. And if you had sedan WRX you probably had rear limited slip too. :D
    First snow you will see what I mean and I would suggest taking very easy.
  18. May 25, 2011 at 12:19 PM
    TacomaPrime
    Greg
    Illinois
    oh yeah. Will definitely have to take it easy. gotta get used to it.
    I am sure it will be fine. We don't have snow on the roads enough around here to really make it matter I think.
