When will Tacoma get bluetooth connectivity?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Jun 4, 2015.
  1. Jun 5, 2015 at 11:54 AM
    #41
    slc_tacoma
    slc_tacoma Well-Known Member
    SLC, Utah
    2015 Tacoma
    I do agree: they have little or no motivation to provide these features. It also likely helps ensure a strong "relationship" between customer and dealership, which in turn keeps the dealerships happy with the manufacturers also.
  2. Jun 5, 2015 at 11:58 AM
    #42
    1MK
    1MK Desert Explorer
    Southern California
    Spot on.
  3. Jun 5, 2015 at 12:03 PM
    #43
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I am trying to fight against that tooth-n-nail. I would like to help Uber-ize automotive maintenance by expanding access to information and open-sourcing. I see that coming in the future. There will be only so much in the future manufacturers of anything (not just vehicles) will be able to keep their data secret, there will be aftermarket solution to hacking into any piece of hardware and as for software it is already easy. E.g. jailbreaking iPhone
  4. Jun 5, 2015 at 12:05 PM
    #44
    foampile
    Mid-Atlantic
    E.g. are there aftermarket ECUs that you can replace the OEM so that it shares its data via Bluetooth, since the OEM won't do that ?
  5. Jun 5, 2015 at 12:15 PM
    #45
    foampile
    Mid-Atlantic
    I never thought it'd be easy
  6. Jun 5, 2015 at 12:53 PM
    #46
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    This is exactly what you got and this is exactly why there's a standardized OBDII port to begin with.
    Otherwise, manufacturers can require each shop to buy their own customized proprietary $20,000 engine interface diagnostics computer.
    That you have to read it in standardized OBD-II format instead of Bluetooth, when there are commonly available converters available at low price, is just whining.
    DoorDing likes this.
  7. Jun 5, 2015 at 1:01 PM
    #47
    slc_tacoma
    SLC, Utah
    2015 Tacoma
    well, not only that but since emissions is done via code pulls and sensor-ready checks, standardization was/is necessary. In terms of core competency, I don't think even money hungry manufacturers want to waste time supporting a proprietary diagnostics system.
  8. Jun 5, 2015 at 1:04 PM
    #48
    foampile
    Mid-Atlantic
    The Uber reference was made to denote a sort of liberation, if you will, from the traditional limitations of accessing services, data, and evading rigid regulations that were possible due to the lack of adequate technology in the past. So it was perhaps a metaphor to what control over our lives us Average Joes can attain by using technology that is at our fingertips
