When's the last time you serviced your rear differential?
Discussion in '1st Gen. Tacomas (1995-2004)' started by m83, Nov 3, 2013.
  1. Nov 3, 2013 at 8:04 PM
    m83
    m83 [OP] Member
    WA
    2004 Tacoma Sr5 Xtra Cab
  2. Nov 3, 2013 at 8:21 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    You mean replace the gear oil? I do mine every two years or 20k. Probably overkill.
  3. Nov 3, 2013 at 8:22 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  4. Nov 3, 2013 at 8:25 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Did mine at 60k with Amsoil severe gear. Now it can wait for a long time.
  5. Nov 3, 2013 at 8:27 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Did mine at the 5 year mark (truck had 15,000 miles.)
  6. Nov 3, 2013 at 11:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I did mine just before the big meet this past august. Always use Redine 75W90 synthetic.
    Toyota recommends changing the rear diff fluid every 30K for normal use. Mine sees a lot of offroad miles so a tend to change it more often.
  7. Nov 4, 2013 at 6:34 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Per Owners Manual recommendations...... Mine's been done twice since I've owned the truck. Once at 26,000 and again this past summer at 58K. If I still own the truck in 3 years, I'll do it again at 90K.
    Since I have 4WD, the front diff gets done at the same time as the rear.
  8. Nov 4, 2013 at 6:35 AM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I change mine every 30,000...however its never dirty nor do I find any metal shavings...I don't offroad much either
  9. Nov 4, 2013 at 6:59 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Yesterday
  10. Nov 4, 2013 at 7:00 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    never 160+k :cool:
  11. Nov 4, 2013 at 7:44 AM
    Madjik_Man
    Colorado Front Range
    I have at least 100,000 miles since I've done mine.
    Doing it in the next week or so.
  12. Nov 4, 2013 at 7:48 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    when i bought the truck: ~87k miles. had the truck regeared at 97k miles so around 125-130k miles i'll do it again.
  13. Nov 4, 2013 at 8:28 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    8 days ago! every 30k miles for me
  14. Nov 4, 2013 at 11:23 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    :eek:
  15. Nov 4, 2013 at 11:24 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Second Time at 50,000 miles... used 75/140 Mobil 1.
