Where are my electrically competent people out there?
Discussion in '1st Gen. Tacomas (1995-2004)' started by REDeye jedi, Jun 9, 2020.
  1. Jun 9, 2020 at 8:10 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Ahaha :D
    Um do call the manufacturer otherwise ....
    :anonymous:
    REDeye jedi[OP] likes this.
  2. Jun 9, 2020 at 8:12 PM
    REDeye jedi
    REDeye jedi [OP] Well-Known Member
    Brendan
    Palm Springs
    2001 Tacoma prerunner 3.4l
    LOL. yes, I'm going to call them tomorrow for sure. And if neither of the switches I bought work. I guess I have two mods I'm going to need to figure out to use them.
    davidstacoma[QUOTED] likes this.
  3. Jun 9, 2020 at 8:17 PM
    davidstacoma
    David
    NC
    Oh you’ll make it work, got confidence in ya man!
  4. Jun 9, 2020 at 8:51 PM
    Glamisman
    Glamisman Well-Known Member
    usually the powers and grounds are switched externally to the device, when one wire gets power the other acts as a ground then when the "ground" wire gets power the "power" wire acts as a ground.
    hope this helps.
    davidstacoma and DrZ like this.
  5. Jun 9, 2020 at 8:52 PM
    JAMES399
    JAMES399 EL CAPO
    JAMES
    Alejandria Antioquia Colombia S.A.
    White 2003 Hilux DCSB 4x4 HI-RIDER +. 2.4L I-4, 5 spd.
    275/70R16 tires, gasolina or CNG fuel, Konig shox, Energy Suspension poly bushings,
    If you already have the switch, just wire it up like this.
    - JAMES
  6. Jun 9, 2020 at 9:11 PM
    rtadams89
    rtadams89 Well-Known Member
    Phoenix, AZ
    2017 Tacoma Limited
    The tailgate lock taps into the two door lock wires, so it works the same way the door lock does. If you connect the blue wire to positive and the green to ground, it unlocks. If you connect the green wire to positive and the blue to ground, it locks. Therefore, if you want to control the tailgate lock independently you need a momentary DPDT (double-pole, double-throw) switch. You wire it up such that in one direction the green wire is connected to a positive voltage source and the blue is connected to ground, and in the other direction the blue wire is connected to a positive voltage source and the green is connected to ground. Alternatively, you could still splice into the door lock wires as detailed in the manufacture instructions, but additionally add a latching SPST switch or momentary switch in line with either the blue or green wire. The tailgate lock would then be controlled by the door locks by only when you have (or don't have -- depending on what switch you go with) the secondary switch engaged.
    davidstacoma and cruiserguy like this.
  7. Jun 9, 2020 at 9:40 PM
    REDeye jedi
    Brendan
    Palm Springs
    thank you. I dont have the switch but it will be here Thursday.
  8. Jun 10, 2020 at 1:23 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I see I did not understand when you said door switch I thought you meant the switch for the dome light in the door .
    Not having Power Door Locks I never gave that a thought
  9. Jun 10, 2020 at 10:03 AM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    I apologize for hijacking your thread, but it seems to be full of electrically competent people. How do you guys wire multiple switches that require dash light circuit connection? A junction block or something similar?
  10. Jun 10, 2020 at 1:13 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Jump them all to the same fuse port or wire that you’re tapping into for the dash light.
    I kinda did something similar. I put two switches under my ash tray and just jumped both of the led terminals together and then connected one of them to the fuse/wire that gets powered when the dash is lit up.
    jeg0005[QUOTED] likes this.
  11. Jun 10, 2020 at 3:21 PM
    jeg0005
    Jon
    BHM, AL
    Which fuse port did you use to make the LED for the switch (in the OFF position) to light up when the headlights are on? I know "TAIL" in position 8 will work, but I'm looking for one in the driver side fuse box in the cab.
  12. Jun 10, 2020 at 6:13 PM
    goldentaco03
    Liam
    NJ
    When I was researching this last time I remember finding that you need to just splice into the wire that goes to the lights inside the dash. This sounded like too much work, and it’s a bitch to dig around under the dash. So I just ended up tapping into a fuse that would turn the accessory off when the key was removed from the ignition, this is more important to me than having the switch light up when the headlights go on.
    I can take a look at the wiring diagrams real quick and see what I can remember.
  13. Jun 10, 2020 at 6:26 PM
    goldentaco03
    Liam
    NJ
    This is from the FSM for an '03 with a tachometer, but I assume it would be the same for other trim levels and years.
    So you are looking for a green-red wire that comes into the firewall and goes up into the dash. That gray rectangle with the "3C" in it and the numbers 14 and 16 is a junction block or wire harness connector, and I believe those are the pin numbers (14 and 16). So you want a green-red wire coming from a connector and going up into the gauge cluster. I can post the full schematic pdf for this and tell you what page numbers I looked at if you would like.
    Edit: doing a little more research in the FSM it seems like connection 3C is the connection between the instrument panel harness and junction block number 3 which is located on the left side of the instrument panel. Feel free to DM me and I can give you much more detailed instructions and send you more pages from the FSM.
  14. Jun 18, 2020 at 11:22 AM
    jeg0005
    Jon
    BHM, AL
    Could you take a look at how I plan to wire this up and tell me what you think?
    goldentaco03[QUOTED] likes this.
  15. Jun 18, 2020 at 12:00 PM
    #35
    jeg0005
    Jon
    BHM, AL
    Sorry, I thought that I posted the link. I sent you a DM.
